Hey SAU'ers. I have been searching the web and there are so many different ways to setup a catch can.
Seeing as I do not completely understand the breather hose setup, this seems a bit confusing and frustrating to me.
I have mocked a picture of what I think is a suitable setup.
Can one of you please guide me in the right direction?!
The green dots are where I think I should remove the hoses and block them off. But then it dawned on me, how does the catch can release pressure?! I know that venting to atmosphere is illegal. So how do i keep it as legal as possible?
Any help/guidance is much appreciated.
  • Replies 43
Posted Images
If you block the PCV then you vent to atmosphere. If you leave the PCV functional then you plumb the catch can back into the intake pipe. My advice is to leave the PCV functional...
rb25 has PCV running of the throttle side cam cover, doesnt it...
when I replaced the rb25 camcovers for rb26 ones I installed an atmo catch can...
If I were to block the atmo vent on the catch can where would I plumb that back too???
if the catch can is properly baffled (ie it catches any oil in the vapour and drains it to the bottom) you can run a 3rd line back to the intake port..
Basically like this in my crappy 30 sec paint job, and then a return line plumbed back into the sump unless you like removing it every now and again to drain the oil buildup.. Or look up a nismo oil air seperator and do it the easy way :)
Positive Crankcase Ventilation Valve, it sucks the oily gasses out of the rocker and dumps it into the manifold but only on vac.
I have a secondary sealed catch can for my PCV, it works well as I used to blow oil smoke on startup and now its clear. Keeps the manifold clean too.
Lol, Damn nismo and their crazy prices.
OI hijackers, this is for rb26. answer my question first then you can continue
Thanks for the quick mockup.
But lets say there are only 2 ends on the catch can.
Then you need to block the PCV and vent to atmosphere and it's going to be illegal, simple as that. For it to be legal you need to have the PCV operational which requires a third fitting on the catch can to plumb it back into the intake.
Edited by Hanaldo
Will this be efficient?
*excluding the breather though.
No. The can needs to vent, whether it is to atmosphere or back into the system. I think you should read up on positive crankcase gasses. If the can can't vent then essentially what you are doing is blowing all this pressure into a sealed can, which will basically pressurize your crankcase until it pops your dipstick out and can vent.
The pressure needs to go somewhere, that's the idea behind the breather setup.
this how i have done it, I turned the fittings on the cam covers to face each other and put a pipe to join them aswell as the catch can on the top of the engine, then capped off one of the outlets of that can and ran a hose from the other one to the front catch can then from there I run hose back around to the inlet of the back turbo with a T to run a hose to the PCV.
hope you can use something from this
Ah, I see.
So just move it to the right of that top pic.
Hook it up to the right side of the rocker cover and there where it goes to the intake. That should mean that it can at least breath and hopefully seperate the oil. correct?
So the above catch can system would work if you block the pcv, the pic above has the pcv connected, and also running to a catch can who h vents to atmo?
Seems like alot of confusion when it comes to hooking one up properly
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
