Hey guys
just a quick question
I bought a skyline r34 gt-t and am trying to get a road worthy certificate for it and it needs to have a washer bottle to squirt fluid on the windscreen.
The standard washer bottle has been removed in order to fit a front mount intercooler. What do people think i should do, is it possible to use a smaller washer bottle off another model car and adapt the skyline pumps from my car to pressurise it? or should i try and replace the washer bottle and pumps off another car and try and rewire them to work in my car?
any advice is appreciated just wondering if someone has alraedy been there and done that?
Thanks
The greddy fmic on r33 comes with a smaller washer water bottle with a stand and space for both small factory pumps to fit in.
I have the greddy washer bottle sitting my garage as I replaced it with an arc combo oil catch washer water stainless thing.
so I'm willing to sell it if it helps you, they supply it so the fmic piping fits right
Same query here ^^^. Pics would be very appreciated. At the moment I'm running the nozzle with cap but no washer bottle haha!! So when the cop opens the bonnet the 'washer bottle' is there but when u open the cap to pour water it falls down into the ground cos theres no washer bottle below haha!!:laugh:
you getting it from your local auto parts store hanaldo & where are you gonna mount it?
Yeh man, got it from Auto1. You could get them for cheaper if you bought online, I just didn't want to wait for it to be delivered. I'll be mounting it in the stock position, under the battery tray in the left hand wheel well. It just doesn't have a filler neck, the cap sits under the stock hole so I can open up the cap and fill it up but it doesn't impede my space in the engine bay. Very neat. Looks sorta like this to give you an idea:
Pictures will be up in my build thread possibly this weekend if I can be bothered getting some bolts for the brackets to mount it :P I was going to just ditch the washer bottle completely but I'm in the habit of doing things properly, especially when it isn't hard.
hahah thanks man, I tried to fit in the stock bottle rotated 90 degrees as some people have done, but its pretty long and fouls a few bits so I couldn't be farked trying to do it, will get a Supercheap bottle when I can, as for bolts and brackets, why not use zip ties if you can! Dodgy as a Dodge Silverado!
Lol trust me, you get sick of the knocks and rattles that come as a result of doing dodgy things like that. Do it once and do it right or don't do it at all. I'm going to make damn sure that mine is rock solid, the stock one used to rattle against the front bar and it drove me insane. Never again.
I was planning to run the stock washer bottle as i think it will fit back under the guard... If it does ill get a smaller battery and rotate it 90 degrees so everything remains sort of factory....
If that plan goes to shit, like most plans with the 34 have so far i will likely get a smaller version of what Hanaldo had made :thumbsup:
JJ were selling one but i think it was GTR only?
^^ same issue here , washer bottle nowhere to be found when I bought mine fmic must have taken all the room but i havent popped the front bumper off yet.
Pics would be awesome ,
I bought a R33 washer to see if i could pop that in the top next to the battery but its wayy too big.
I picked up a supercheap universal bottle which seems to fit but downside is theres only one motor in it
some pics of fixes and solutions would be great... i hate driving with dirty windscreens....
on that note , i had a blonde moment where i couldnt take the muck on the windscreen any longer and i had a bottle of water next to me .
i proceeded to try and pour some water on the windscreen (while driving) and the wind ended up blowing it all back into my face.
i sat back thinking....wow that was dumb....
  • Haha 1
Yes, I should mention that my rear washer doesn't work. It hasn't worked since I put the new engine in, as I used a washer bottle with only one pump. Not sure about over east, but in WA it's only a requirement that the front windscreen washers work, so I'm not fussed about the back one. Back one never seems to get dirty anyway :P
Are you the local Mr Bean????
lol it was a good idea at the time =p
btw i found something that might help... since stagea's and r34's are similar in some ways
http://www.skylinesaustralia.com/forums/topic/322568-just-fitted-a-fmic-kit-to-my-series-2/page__p__5261900__hl__+washer+bottle+r34+fmic__fromsearch__1#entry5261900
now all i need is an actual stock washer bottle...
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
    • From what I understand, the normal Nismo diff is a bit harsh, and the Pro is the one that behaves more nicely, and you only pay Nismo tax twice to get it.
