hey selling my work VS rims they weight just 7KG each , fronts are 7.5in and rears are 8.5 in , as they where on my r32 GTR witch i no longer own,
they come with tyres that are pretty good, all but 1 rim is perfect , 1 rim needs repainting could be done with a 3 dollar spray can.
the bad rim is pictucred so you can judge for your self , i paid $2200 for rims only.
pick up is probably better on theys just because of the size and weight but might be able to help drop them off if its not too far.
located in Newcastle.
Price $1600 ONO
any questions feel free to ask
Hey selling my T04Z garret turbo , as i no longer own the car it was on.
it was on my r32 gtr making 330rwkw on 18psi , and was never boosted past 18psi as i didn't have the fuel system that would allow for it.
the turbo has done about 7000kms since being bought new and a 1000 of it was melb to back home.
turbo comes with greddy 2 into 1 air intake for you guys still runing afms :) and has the vband rear 0.82 housing.
$1600 ono + shipping if needed
any qustions just ask
Hey selling my apexi Power FC, as i no longer own the car.
was on my r32 gtr making 330rwkw.
comes with hand controller but needs the plug put back on :(
800 ono + shipping
any questions just ask
hey selling my seats out of my gtr , as i no longer own it.
the front seats are R33 GTR seats , passenger perfect , driver pretty good bar 1 small rip and 1 small stain witch would probably come out.
the rear seats are R32 gtr std rear seats witch are in perfect condition bar a little bit of fading in 1 spot.
pick up is probably the only option with some thing this larage but maybe i could organise them to be dropped off it if its not too far.
item's located in Newcastle.
price $850 ONO
any questions ask
I'll give you $500 excluding postage for the gtr seats mate but will need to be posted to WA. Postage is pretty straight forward, you'll just need to use DHL as opposed to Australia Post.
James
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
