Hello SAU,
1994 R32 GTR
Engine, just under 15,000 km put on since rebuild (Weekender)
ENGINE
- R33 Block, all internals have been changed or modified
- Crank
- Forge Pistons
- STD Rods
- ACL Race Bearings
- Head Studs
- N1 water and oil pumps
- GT 2860-5 turbos
- HKS dump pipes and front pipes
- Very hi flowing cat
- HKS Hi Power Silent Exhaust
HEADWORK
- Custom grind camshafts (264/264 11.0mm Lift)
- Mine's adjustable cam gears
- Valves , springs, lifters and all to suit camshaft profile
- Extensive porting on intake and exhaust sides
EFI
- Sard intank Fuel pump
- SARD Fuel Rail + Fuel Pressure Regulator
- SARD 700cc Fuel Injectors
- Platinum PRO
INTAKE/COOLING
- 110mm thick intercooler
- HKS intercooler hard pipe kit
- Twin K&N Intake + Airbox
- Aluminium Radiator
- Oil Relocation Kit
DRIVETRAIN / SUSPENSION
- Reconditioned Gearbox
- front and rear LSD's
- 17x9 inch Volk Racing GTU (Tyres still have plenty of tread on them)
- BC Coilovers
- Reconditioned Front Driveshafts (Boots were ripped, installing them this weekend)
INTERIOR/EXTERIOR
- Haltech Platinum Pro now running on MAP Sensor
- HKS DB Chrono meter gauges, (boost, exhaust temp, water temp, oil pressure)
- Turbosmart e-boost street boost controller
- Clarion single DIN DVD Player, mp3 divx all that stuff
- Fusion and clarion speakers
- Trust Side skirts and Rear Pod
- Top Secret rear Diffuser
Car has ran an 11.4 @ 117mph 1.6 60ft when it was making 312kw (N1 Turbos) with the old Setup
Have not been back to the track since the new build. Car recently tuned at JEM (12/03/12) made 347kw atw @ 20PSI, 819.6 Ft LB of Torque.
PRICE: $24 000 ono
Contact: PM or 0404 059 305
https://www.sau.com.au/forums/topic/395643-eoi-1994-r32-gtr/
  • 1 month later...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
