Up for sale is my 180sx drifter. It is NOT registered and is a track purpose car atm. It is possible to have it registered but it requires a bit of work to get it there.
looking for $7000 ONO
Perfect first drift car for those looking into starting up drifting. It is a fully gutted car including rear seats, all of the carpet, rear seat belts spare tire etc. It has a full engine conversion from a blown red top SR to a 2002 Australian delivered specR S15 black top SR20. The engine only has around 80,XXX Ks on it while the chassis has about 208,XXX ks. Has a bit of a bodykit on it (front bar and rear pods) and is half white, half matte black. I have owned the car for 9 months and a lot of work has been put into the car to get it up to where it is now. Reason for sale is that I can not afford two cars at this time and I need to fix a few problems with my daily. Also looking into purchasing an AE86 in the future. Not 100% positive of what the car is running power wise (it not being registered and in a suburban area don't have much of a chance to take it for test runs) but it has a set and forget boost T which has been turned up a little so I think the car is running around 10psi and hitting about the 170rwkw area.
Only things not working on the car are the reverse lights, rear wiper and dash, all of which are easy wiring fixes that I haven't found time to fix yet. There are also two perished power steering hoses that are slowly leaking out power steering fluid. As long as you top up the fluid before driving the power steering works perfectly fine. Pretty sure it has a full 3' exhaust with a gutted cat.
Here are some of the features of the car:
2002 S15 blacktop SR20
Buddy club adjustable coilovers
Power FC (with hand controller)
Front mount intercooler (HDI brand)
Drift Pod filter
Shadow water temp sensor (not wired up to a gauge yet)
Type X taillights
Carbon boot lip spoiler
Engine brace
Front bar (similar to GP sports front bar) link- http://www.avb-sport...91/00013670.jpg
rear pods
17'x7 Akuma wheels
Federal 235/45/17 70% on the rears
Stiletto Blue streak 225/45/17 90% on the fronts
Power steering
central locking
power windows
Air con (no heating due to heater hoses being looped)
Overall it is a fairly stock car and a perfect base to build on. Handles well and is easy to learn in. There is no rust from what I have seen and the car runs well since the engine conversion and suspension upgrades. Car includes (optional) 9 spare wheels (180sx stockies, all of them need rubber), 3 spare front panels, stock front bar, S15 Helical LSD diff, and a few other bits and peices (stock parts, bushings and hosing etc). Any questions feel free to PM me or txt me on 0401398769.
Plates are not included
https://www.sau.com.au/forums/topic/395658-180sx-drifter/
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
