hi all first post....
So basically im after a R32 or R33 Gts-t. clean with low kms, minor-no mods.
I have previously owned a 33 great car but i am leaning more towards a 32 this time around. basically i need some help in to deciding what car would be best suited (reliability, affordable etc)
these are some pros and cons ive researched between the 2 models. Can you guys give me a few not so obvious pros and cons?
RB25 Pros
Newer
Easier to attain more power in it's stock internal form
N-VCT (Nissan Variable Cam Timing)
Beefier Tranny
Better head design than the 20
Stroker kits available
More torque
RB25 Cons
More expensive
Lame Turbo (Better than the 20 though)
7,000ish Redline
Weak piston ring lands
Harder to tune than the RB20
Side Feed Injectors
RB20DET Pros
8,000 Redline
Cheaper
Easier to tune than the RB25
RB20DET Cons
Head doesn't flow as well as we would like
Lame turbo
No N-VCT
Harder to get more power in stock internal form
Weaker tranny than the RB25
Older
Makes almost the same HP as a SR20DET out of the box
270CC injectors (stock)
https://www.sau.com.au/forums/topic/395713-rb20-vs-rb25/
RB25 Cons
Side Feed Injectors
Wrong
Wrong
Irrelevant
RB20DET Pros
Wrong
Also realistically “low” km cars don’t exist unless you have full & authenticated service history. It’s 2012 – No standard issue R33 from ‘95/’96 is going to have 70,000km’s on it. 99% of them have simply been wound back.
R33 Chassis is better than a R32 one either way. They are a better built car, evident by the extra weight as well of course.
Also remember that Nissan electrics aren’t the best once they get older. So things like CAS, AFM, Dash & general gremlins creep in. Not everyone suffers but it can happen.
It doesn’t sound like your about to go through a 350rwkw rebuild, so just get as later model of R33 as possible – simply reduce the chance of headaches.
https://www.sau.com.au/forums/topic/395713-rb20-vs-rb25/#findComment-6287452
Doesn't it all just come down to money then mate?,most people I know would go the 25 and myself to if the funds were in the bank. Dont get me wrong i love my 20 and it does take a bashing and still is living happy but the 25 is just a bigger newer engine, flows better and can make more power with minimal mods...seems to me then ur only dilemma is the body, a nice sexy looking 32 or a hideous 33 rolleyes.gif .Good luck with u choice.
https://www.sau.com.au/forums/topic/395713-rb20-vs-rb25/#findComment-6287751
Well im heading back to uni so money is a factor. but i want something quick and reliable (being a 20y.o car that may be a bit difficult lol)
At the moment im keeping my options open, but still wanting advice/opinions from people who have owner either or both cars.
Cheers
https://www.sau.com.au/forums/topic/395713-rb20-vs-rb25/#findComment-6297894
i love the 20 in my 32 but when it carks it i will put in either a 25 or 25/30 (plenty of parts at my disposal) as there is heaps of parts available for the later motor, ive even considered a 25 neo(the STOCK one in my 34 goes like hell)
https://www.sau.com.au/forums/topic/395713-rb20-vs-rb25/#findComment-6298096
    • This is a real nostalgia trip for me, I mean SK Bilsteins? I ran those lol Good times.  Good work Duncan, it's not an easy job in many respects. I'm sure the family appreciates it.
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
