I've got issues with my R33 series 1 , I bought the car at just about 100.000kms it has run perfectly until now.
some of the issues I'm experiencing is that it makes a grinding noise (almost like an electric car buzzing) while driving Ive checked driveshaft in case it was hitting exhaust
and there was nothing ive checked oil levels and they were normal, Ive looked under the engine bay and i discovered that the PS pump leaks and also my belts squeals,
Im doing it pretty tight at the moment and dont have much money for a mechanic, so im just wondering how bad is this problem and how it can be resolved as cheap as possible.
there is now steering shakes or jitters nor are there noises from exhaust.\
I HOPE SOMEONE CAN SHED SOME LIGHT ON THIS AS ITS BUGGING ME AND THIS IS MY ONLY DAILY DRIVE :(
I will put pictures up soon of the engine bay from below.
https://www.sau.com.au/forums/topic/395755-help/
Hey mate, you could be having a wheel bearing problem possibly, the noise usually comes and goes depending on which way the vehicle is moving, ie: when loading the wheel with a bearing issue the noise is louder, when unloading the noise disappears.
https://www.sau.com.au/forums/topic/395755-help/#findComment-6287881
if the steering wheel vibrates/feels 'notchy' as you turn then it is most likely caused by a dodgy power steering pump. check that you have enough fluid in there in case it is just a low fluid issue.
also you don't want your belts super tight. just tight enough, otherwise you will shag the bearings in the pulleys.
https://www.sau.com.au/forums/topic/395755-help/#findComment-6288145
No mate no steering problems whatsover noise is coming from bottom right hand side pulley i think its the a/c tension pulley???
can that be easily replaced??? I've downloaded the workshop manual for rb25de and it shows how to pull apart but i want to know if theres any tips on how to do it easier or what to look out for before proceeding?
https://www.sau.com.au/forums/topic/395755-help/#findComment-6288773
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
