hey guys i looked under the car today ( have not driven it for about 6 months) and noticed a 50cent size oil patch on ground just under the bell housing however when you look to the back of the box near the drain plug yu can see where oil is about to drip but it also seems to be going to the back of the box also but not dripping onto ground. i cant seem to find where it is exactly coming from and it is deceiving. is this a common problem could the drain plug just be leaking as it is still tight. or is it something more serious like rear seal or input shaft seal
https://www.sau.com.au/forums/topic/395762-deceiving-gearbox-leak/
Did you smell the oil? It could be engine or gb oil.
+1, and the reason this is being suggested is that the rear main seal (rear of block to crankshaft) can leak engine oil out at the bellhousing.
found the leak thanks guys one of the rear housing bolts to the box was a little loose and was leaking and the leak towards the front is actually my exhaust side cam cover leaking down the back of the motor
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
