Hey guys
i decided to go for a drive in my 32 last night, i hadn't driven it for a week and it has developed some strange issues; the HIDs were flickering on and off, and the power steering was cutting out and there was a high pitch buzz coming through the speakers.
the only thing i have done to the car recently was put new coil packs in and re gapped the spark plugs, but that was 3 weeks ago and it was running fine until now...
I know its hard with electrical fault but i was just wondering if any of you have come across this before or you have any suggestions for me?
https://www.sau.com.au/forums/topic/395795-r32-gtst-electrical-problems/
Yea unless there is one under the valley cover i forgot about the only earth i would have touched would be the one on the ignition pack, which seems fine... but i just went and double checked it and the car has lost all power now, the battery is still nice and tight and reasonabley new, so i guess ill have to pull the multi meter out tomorrow.
So yesterday i tested the battery and found that when its disconnected it has approx 12.04v then when i hook it up it drops right down to 2.01v... i tried disconnecting the HIDs, audio system and coil packs one at a time with no change in voltage (they are the only aftermarket electrics in the car) so my thoughts are there may be a short somewhere?
I put a new battery in about 3 month ago.. but this one may be rooted because i know my amp was killing the battery (i took that out a few weeks back) i just thought if the battery was gone it would have had more trouble starting when i first noticed the issues with the headlights and power steering... And there seem to be something drawing way to much current anyway coz it drops 10v when i hook it up... but ill see if i can borrow a healthy battery from one of my mates and see what happens
Yea i tried that and had no notable change.. I went and got a battery print out this afternoon and it said "charge system failure" so looks like an alternator.. im told that they can collapse and the internals can touch together which could be causing the drop in voltage..
So i fully charged the battery and started up the car with a multi meter hooked up to the battery; started out at about 12.8 volts and dropped down to 12.2 as the car reached operating temperature.. when i reved the engine the reading went up to 13.2, so the alternator seems to be charging the battery. i turned on the headlights ac and radio and the volts dropped to 11.65.. i took the car for a drive and re tested the battery and nothing changed.
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
