Hi
I am looking at converting from auto to manual in the next few months.
I’ve go some of the parts like the centre console and the handbrake and pedal set.
Has anybody on this forum done a conversion or got a link to one?
https://www.sau.com.au/forums/topic/395836-v35-350gt-manual-conversion/
It's not so much different than swapping the trans on any other car. Your biggest concern is the e-brake relocation and TCU (transmission control unit). You'll want to try to get parts from the same year model as your own car.
After that it's all about either the technical knowledge, or deep pockets.
The mechanical side should be straight forward (meaning, like any other auto-manual swap), you just need all the parts. You might run into issues with the auto ECU, some of them need to be able to talk to the TCU, so you may need to leave that in place. I have also heard of idle issues with these sorts of swaps. Idealy you should swap in a Manual ECU too, but this might need a harness change.. but if a can of worms.
Safest option (and possibly cheaper) is to sell your car and buy a 6MT version.
Too much hassle. Like sonicii said, just sell the auto and get a manual.
Don't forget all manual V35s come with Brembo brakes and LSD from factory. So if your car is 03/04 series 1 model you might need some work done to the brakes too.
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
