Hi all
if anyone has an old standard M35 turbo they want to sell (or loan), please let me know.
It doesn't have to be working, as long as there are no cracks on the inner turbine & compressor housings.
I'm wanting to get one high flowed & then swap over with mine so as to have minimal time off the road.
Will be happy to return my turbo after this if you want it for your own project (it could be better than your current one).
Alternatively, in the interests of helping out the community, I can make it available for others who would like to do the same swap as me - sort of a loan turbo.
Cheers, Leon.
https://www.sau.com.au/forums/topic/395845-wtb-m35-turbo-suitable-for-hi-flow/
Hi all
Cheers, Leon.
Sounds like you might be going down the Hypergear route?
I'll also be interested in utilising a loan turbo in a few months if someone is prepared to make one available, or if you want to defray the cost a bit Leon.thumbsup.gif
I would lend my housings out but there's no guarantee I would have a good set if I ever decide to put it back in. I may know where to get another damaged turbo though, I will get back to you.
You guessed it, lol. It looks like the best value option for my needs, but I've only really been thinking about it for a few days.
It makes sense to me to have one ready to go in at the same time as you take the old one out. Could be a bonus if you're paying for workshop time, or if (like me) you forget how you got the bolts out the week before.
Thanks Scott, it'd be great if you stumbled across one in your travels. I'm in no particular hurry as my car is still driveable, for now.
Didn't I read recently where you said you hadn't seen a standard turbo with a cracked housing? But I wouldn't be lending yours out if it is still in good working order.
I've got one too FYI Leon.
Cheers
Haha, they're everywhere it seems. Thanks mate, but I think I'm right to go.
Good to know Jase, I might need one too! :thumbsup:
Did you high flow yours?
That was the plan, just haven't gotten to it. That said, I'm not sure my spare is even stuffed? Has no side to side shaft play, maybe a little in-out play.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
