Hi all
if anyone has an old standard M35 turbo they want to sell (or loan), please let me know.
It doesn't have to be working, as long as there are no cracks on the inner turbine & compressor housings.
I'm wanting to get one high flowed & then swap over with mine so as to have minimal time off the road.
Will be happy to return my turbo after this if you want it for your own project (it could be better than your current one).
Alternatively, in the interests of helping out the community, I can make it available for others who would like to do the same swap as me - sort of a loan turbo.
Cheers, Leon.
https://www.sau.com.au/forums/topic/395845-wtb-m35-turbo-suitable-for-hi-flow/
Hi all
Cheers, Leon.
Sounds like you might be going down the Hypergear route?
I'll also be interested in utilising a loan turbo in a few months if someone is prepared to make one available, or if you want to defray the cost a bit Leon.thumbsup.gif
I would lend my housings out but there's no guarantee I would have a good set if I ever decide to put it back in. I may know where to get another damaged turbo though, I will get back to you.
You guessed it, lol. It looks like the best value option for my needs, but I've only really been thinking about it for a few days.
It makes sense to me to have one ready to go in at the same time as you take the old one out. Could be a bonus if you're paying for workshop time, or if (like me) you forget how you got the bolts out the week before.
Thanks Scott, it'd be great if you stumbled across one in your travels. I'm in no particular hurry as my car is still driveable, for now.
Didn't I read recently where you said you hadn't seen a standard turbo with a cracked housing? But I wouldn't be lending yours out if it is still in good working order.
I've got one too FYI Leon.
Cheers
Haha, they're everywhere it seems. Thanks mate, but I think I'm right to go.
Good to know Jase, I might need one too! :thumbsup:
Did you high flow yours?
That was the plan, just haven't gotten to it. That said, I'm not sure my spare is even stuffed? Has no side to side shaft play, maybe a little in-out play.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
