Hey guys, just a question to throw out there, But I have a 34 GTR running 350kw with a Nismo supercopper mix which is only 6 months old.
However the clutch pedal has recently been getting softer and seems to have less travel, does anybody know what causes that? ive bleed the clutch but that didnt seem to fix anything.
Also my old R34 had clutch problems with the hydraulic parts, and i dont want to waste money with the GTR, is it possible to convert it to a pull type cable clutch?
Have a look at getting your slave cylinder re-sleaved. Its probably leaking past the piston and reducing travel at the throw-out lever. The master cylinder can also need attention, but usually the slave is in worse shape.
Also bleeding these can be tricky, as they have a loop for "cooling" the clutch fluid... which creates a nice air trap. Look for a block with a bleed fitting located directly down and back a bit from the clutch master cylinder.
The only upgrade worth considering is swapping out the loop and stock plumbing for the nismo braided hose that goes directly from the master cylinder to the slave.
Push to pull conversions relate to using different types of clutches in the R34 gearbox. All require gearbox removal. None would use a cable. They are all hydraulic and all use the booster so that your pedal doesn't feel like your driving a 5 ton truck. The stock systems work perfectly when they are in good condition.
I have decided to upgrade with a braided hose straight to the slave, but would u recommend the nismo slave or a genuine Nissan one? can the genuine one handle a supercoppermix clutch? or am i wasteing my time with that? also im sure its on SAU somewhere but its a R34 GTR a push or pull slave cylinder lol ?
Keep the standard slave cylinder and just re-sleave it. Once its fitted with a stainless sleeve it will out-last the life of the car.
The Nismo one has reduced throw due to having a larger piston bore, and can lead to problems like you are already having.
The braided hose is really going to help you bleed it properly.
Standard copper mix clutches handle 400kw easy. They rate them as a 600ps clutch (around 590-600hp). There is a competition version that is rated at 780ps if thats not enough. I've got a modified early version in my car and its still mild enough to drive to the shops or in slow traffic.
Edit: All slave cylinders "push". Its the operation of the throwout lever moves the throwout bearing that determines push or pull type. R33/R34 and some late R32's are pull. R32 are push.
who does re-sleaving, powersteering joint? any business u recommend i can check here in syd?
Anyone that does brake system reconditioning work such as caliper refurbs etc should be able to do it.
Does the nismo braided hose bypass the dampening/cooling circuit? How long is the hose? It must be like 40-50cm long if it does? I've been trying to buy one but don't want to buy the wrong thing
Yes it replaces the loop. Everything you need to know is in the part description here...
http://www.rhdjapan.com/nismo-stainless-braided-clutch-hose-bnr34-r34-12334
You can probably source it in australia easily enough though. I've seen them on Ebay occasionally and just jap or high octane probably have them in stock too.
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
