5 min job. From underneath. Look for a long 10mm bolt facing vertically. There is one for each belt.
Also, inspect the belt for cracking on the ribs on the inside. If its too bad or brittle, replace it.
And don't forget to firstly loosen the idler bolt before trying to tighten the belt. Otherwise the idler won't slide.
Probably obvious but I made that exact mistake!
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-6289409
You can replace your belt with soap!!!?!?!??!?????????!!????,?,!!!!!!!!!!?!,??,?,???!!???!!!!?!?
Instead of using brake fluid which will eat your paint if it comes off the belt lol
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-6289483
  • 3 years later...
Dragging up an old one here, the bearing on my aircon pump or tensioner Seems to be on its way out, I can't quite put my finger on it, has anyone replaced this before? Don't want to pull it off without parts on hand, anyone know the part numbers?
Many thanks,
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-7555667
I suspect it may be a bit of a major - definitely if you lose your coolant. May be a job for an air-cond shop unless someone knows better.
No coolant loss, hard to describe but it's like a chirping sound proportional with revs, comes and goes, my guess is the bearing attached to the pulley on the pump itself might be on its way... Which yeah, could be a major, I'm quite rookie at this fault finding stuff lol
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-7555682
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
