Hello All,
I have a 1995 GTR V-spec for sale if anyone is interested. Details are:
Silver
3 1/2 Inch Full Exhaust
18" Mag Wheels
HKS Valve Controller
Turbo Timer
HKS Piping
External Oil Cooler
Air Conditioning
Power Steering
Power Windows
Power Mirrors
Brembo Brakes
ABS
Hicas
Active LSD
Asking price is $42600 ono
https://www.sau.com.au/forums/topic/39588-for-sale-1995-r33-gtr-v-spec/
Its done a low 30,000kms. I imported it and got my contact in Japan to locate a near new one which it is as you can see from the pics.
Thanks
god damn ! there da enelki rims that i had on my sky. until i had a accident and bent 2 rims- and they couldn't find a replacment
Hi There,
My name is Gavin and I am interested in your GTR. Could you inform me of the FULL details of the car please? ownership years? accident damage? reason for selling etc etc..
Are you neg on the price or shipping to another state?
Regards,
Gavin
Hello Gavin,
Full details of the car, well I imported it in about october 2003 from Japan, originally I wanted a series 8 RX7 but settled for the GTR. I am sellingit because although this is a great car I still want the series 8. Car is in excellent condition with no problems or acident history. Only noticable thing is that one of the lights has dulled. The car hasonly been driven about 3000kms in Australia, most of which has been down to wollongong on the weekends. Apart from that the car is always garaged and is filled with BP Ultimate. Price is a little negotiable but not greatly and I dont mind shipping the car interstate. If there is anything I have forgotten please ask. Thanks
no havent replaced the front left headlight, and if I did I certainly wouldnt have replaced it with one that looks yellow........ I would have bought a nicer looking one....... Im sure it can be cleaned up to look clear again just not sure how......
Very nice GTR
Think the price may be a bit high .... Plus the import market is pretty poor at the moment. Its only worth what someones willing to pay for it.
Ummm, try polishing the headlight with something like cut & polish. Worked for me when I did mine
Cheers
Tom
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
