Hi Guys got a couple of parts for 350GT Coupe
1) A pair of 2006/2007 factory (genuine nissan) Bi-Xenon Headlights, they have all the bulbs all you need to add is the ballasts from your old headlights, these are brand new never installed or used. These are the actual projector Low and High Beam HID and work exactly like the V36 HID's
2) A complete set of Tein S-Tech springs also brand new in box.
Here are the specs for the springs
Front Spring Rate: 6.4 kg/mm / 358 lbs/in
Rear Spring Rate: 4.9 kg/mm / 274 lbs/in
Front Drop: -30mm / -1.2"
Rear Drop: -23mm / -0.9"
okay and now the prices
Lights im looking for around $900 ONO
Springs are $400 ONO
offers are welcome but try and pm them.
Pix attached
contact: Amrit on 0414482636
email: [email protected]
thanks
Edited by AsM
Hi im interested with the spring.. whats the rock bottom price delivered to Sydney?
hey mate, i just checked the mesg, ill find out postage on monday and let you know the final price including postage.
Whats your postcode?
cheers
Edited by AsM
Will the springs go in a sedan?
Hey mate, according to other forums, they do fit but might lower the car 0.5" more than it would do for coupes.
have a look here http://g35driver.com/forums/2585123-post3.html
and here as well http://g35driver.com/forums/brakes-suspension/92682-another-g-sedan-350z-suspension-pix.html
cheers
  • 4 weeks later...
  • 4 weeks later...
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
