Well the time has come to regretably sell my pride and joy R32-GTR. I imported this myself in 2005 and did a bare shell respray in Black with a blue Pearl.
Every Nut , Bolt , seals were replaced with new genuine nissan items when put back together . The car is immaculate and is in pretty much show condition .
I know im going to forget to list everything that the car has on it but i will try my best to list most things.
The engine has probably only done 1500k's since been built as i hardly drive it . Currently sitting on 550rwhp soft tune although makes 600+ if needed (have dyno sheets )
The list of engine parts are :
Brand new n1 block
HKS Pistons
HKS Rods
HKS Oil Pump
HKS Head Gasket
HKS Fuel Rail
HKS fuel Reg
Sard 720cc injectors
Nismo Big end and main bearings
ATI Balancer
Ported and Polished Head
Supertec Valvesz
HKS Step II 272 10.2 MM lift cams
HKS Springs
To4z Turbo with custom stainless steel manifold
Apexi 60mm wastegate
HKS Twin Power Ignition
Splitfire Coilpacks
HKS 130mm Intercooler
Im sure theres plenty i have forgotten regarding the engine so call me for more info.
Some more things the car has.
Ferrari F50 Calipers on 350mm Trust 2 piece rotors ( as new )
Brembo r33 gtr rear brakes
All braided stainless ADR approved brake lines
SSR type c-rs 18 x 9.5 forged bronze rims
Apexi N1 Twin Exhaust System
Bosch 044 Fuel Pump
Bilstein Ajustable shock abosorbers with Eibach Springs
OS Giken r3c Triple plate clutch (as new)
Power FC-DJetro computer
Blitz spec-r boost controller
Defi oil , boost , fuel pressure , gauges
Innovate air/fuel ratio gauge
This car has been meticulously maintained and looked after and would not dissapoint. Is ready for track use if needed but have never done so. Has run 10.80 at 133mph full street tune on street tyres. No expense has been spared making this package super quick and super reliable. Feel free to ring for more info. Located in Perth but more then happy to assist someone in getting it over east.
Looking for $35k ono
Simon 0403364469
https://www.sau.com.au/forums/topic/395900-built-10-second-r32-gtr/
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
