Alright guys,
I've got too many wheels so these have got to go!
1. R33 GTR wheels
sizes: 17x9 +30
PCD: 5x114.3
Tyres: Toyo R888 255/40/17
info: R33 GTR wheels, got them from a friend that did one or two track days on the R888's. Still plenty of meat for the track.
These wheels have been painted black by one of the previous owners.
Price: $1500
2. "Hotstuff" Wheels
sizes: 17x8 +32 17x9 +35
PCD: 5x114.3, maybe 4 stud too
Tyres: Bridgestone potenzas 215/50 (f), Michellen Exelence 235/50 ®.
info: Hotstuff was a small tuning shop in Japan many years ago, that produced all sorts of wheels. These happened to come on my mates R33 when he bought them.
They are similar to the old Sparco wheels, and are made in Japan.
Front tyres are down to the indicators, rears have 1-2mm left. Good for doing skids on.
Price: $800
Happy to ship at buyers expence, located in Liverpool region, Sydney.
Adam.
Edited by Run-It-Hard
Hey mate,
Tried PMing you but function must be turned off.. I'm interested in the 33 GTR wheels
What was the build date on those R888 tyres? And are you willing to post to Melbourne?
Cheers
Edited by adam-__-
Hey mate,
Cheers
Hey, I'll need to check the date for you. More then happy to post at buyers expense.
Only if I can find a buyer for the tyres.
PM your offer on just the wheels, if it's worth my while stripping etc I'll consider it.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
