Straight down the middle of the stud
Cut studs flush with face
Centre punch middle of end of stids
Dril with smallish dril first
Dril again in same hole with drill larger than stud
Use decent metal drills ones for hardened steel would make it a heap easier, dont overheat your drill bit, some drilling compound wil help too
Cause u can probably use the studs that currently hd the wheels on
If you cut the the spacer you cut those studs as well
Us i dont think i would enjoy cutting thru it with cutting wheel on a grinder
I don't understand; of course cutting through the side of the spacer and stud will damage it.
Explain to me how cutting 10mm off them, leaving them too short to use later on, and then drilling down the centre of the stud is going to leave it intact?rolleyes.gif
Are you suggesting drilling through the captive studs in the spacer? You might as well drill a hole in the window for all the good that will do.
Why wouldn't you enjoy cutting metal with a metal cutting disc on a grinder? That's what they're made to do; I'm not suggesting he uses a Chainsaw...
i must say i will try hang out for the tool . iv been out there for 30 mins drilling one out , then try with hammer and chisel , still doesnt want to move... more wd40 is sinking in now , so ill attempt it again.
daelo , i dont think that will work without interfearing with the standard studs
As above ;
The whole point of my post was, that if you were prepared to sacrifice the studs (which you will by drilling down the centre; I assure you); my way will take about 10 minutes a side, versus about 3 hours drilling down the centre of the studs
By the time you've chiselled or welded near these spacers; you're going to throw the spacers in the bin anyway.
New wheel studs are like $5 each. how much fuel and hassle have you spent already, driving all over looking for a tool no-one has?
Edited by Daleo
OK if it were me and I couldn't get a tool anywhere I would go to one of several engineering shops I know and get them to make me one. All you need is a great long lever with prongs sticking out to put on the holes. If you show an engineer ( as in metalworker /welder/fabricator ) the problem I am sure they could whip something up in under an hour which would do the job.
I think the problem will be the cost of the item; if I were to fabricate a tool to do that, it would be close to the cost of a new set of studs. Why bother at that point?
there is two sets of wheels studs here people...
one set that he can destroy to get the spacer off and another set that if he does cut or damage can be used once he removes this crap
I'm not sure you really understand what's going on here. You do realise the longer set are only pressed into the spacer? Cutting these will not release the spacer.
The ones that have the recessed nuts (the ones that require the tool) on them are the issue.
Replacing wheel studs is a simple job; these ones are likely to be corroded anyway; that's why I'm suggesting cutting his losses and just scrapping the spacers and studs.
At the end of the day; he's 11 days down since the first post, and the spacers are still where they started out.
Why worry about wrecking something you're going to chuck in the bin? It's just stupid.
How's it going mate? Got them off yet? Must say I'm leaning towards the directness of Dale's approach - angle grinder, eye protection, ear protection..... away you go. Don't worry about the oem studs - they are inexpensive and simple to replace.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
