Probably a stupid question but here goes anyway.
I currently have aftermarker BOVs fitted to my GTR and they currently vent to atmosphere. I want to install the standard recirculating BOVs and was wondering if it will cause any dramas with my tune when I take my foot of the accelerator given that they will vent back into the system instead of externally.
Can I safely return to the standard BOVs or will my tune need adjusting slightly.
Thanks in advance
https://www.sau.com.au/forums/topic/395937-changing-bovs/
I also reckon it will create a lean spot as the tune will not be expecting that vented air to return (i.e. it would have been tuned so as not to create a rich condition on throttle lift off when the atmo bov dumps the charge air)
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6290291
I'd actually quite like a tuners input on this. How much messing around is done to the AFR's when tuning for an atmo bov? Is it just a little bit of fuel removed to prevent stalling/backfiring at low rpm, or is it enough to cause an issue if it was changed to recirculation? If the adjustments are made for low load cells, ie. ~2000rpm and below then I don't see how a slight lean spot would be an issue. Unless you really have to take out a lot of fuel, or it causes an issue on decel at high rpm, I wouldn't think a retune would be necessary?
Experienced opinion?
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6290423
When I had my twin entry ARC cooler on my GTR I had to remove the BOV return piping to make it all fit. My car had AFM's at the time and it played havoc with the tune. The tracer while tuning would float around. On the road it was horrible!
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291196
I've blocked off my bov before, didn't seem to make any difference at all. Didn't backfire, never dropped revs on decel let alone stall. Only noticeable difference was the sound.
However I never got it tuned like that, so I don't know how much of a difference it was really making. Makes me a bit nervous because I'm not going to have a chance to weld on my bov before I get the car tuned after the Plazmaman install, my fabricator has just had a baby so he is a bit busy. I'd quite like to know if not having a bov on for the tune is going to cause problems...
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291592
It idled fine, started fine but it sent the AFM's into spaz mode. Fuel economy was horrible as it would just 'shuffle' under light load.
I know some guys have no issues and maybe it was just my setup (Choof Choof twin GTRS's).
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291610
The difference between a blocked BOV and a venting BOV is nearly infinite with regard to the effect on where the air goes after it has been through the AFM though.......
Not the same question at all.
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291638
Yes I know, I wasn't implying they were the same, I just thought perhaps the methods of tuning around it were similar given the only real way to do it is to 'trick' the AFM into thinking it's seeing less air. Which means it will have a similar effect when returning it to a plumb back setup, no?
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291647
The difference is the air dosnt escape with a blocked bov it simple goes through the turbo then down the pipes not bypassing the turbo, as I understand it. According the the sensors the air is not "missing"
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291694
It's not missing, but it passes through the AFM again so it gets measured twice. So the effect of the AFM 'thinking' there is more air in the system then there really is is the same, so more fuel is dumped. I imagine the only way to tune around that is to find which cells are becoming too rich, and then leaning those cells out. Now these cells are most likely to be at very low rpm, correct? You're not going to have issues with stalling because you're running a bit rich at 5000rpm, the issue comes around when you clutch in from higher RPM and return to idle. So the cells adjusted should be at a very low load point, meaning whatever lean spot is created by actually having that air in the system shouldn't cause any issues?
Or am I missing something?
https://www.sau.com.au/forums/topic/395937-changing-bovs/#findComment-6291729
    • Thanks for the info GTSBoy, legend. If there is no downside i'll likely just get the larger bosch units because why not... I remember hearing stories about people washing their bores with fitment of too large injectors way back when, which i guess has made me shy about it now. But happy to know it shouldn't be an issue. Ozdavroz, the little rb20 is a lot of fun- now that i have a little extra funds and time i am very glad to be tampering with the ol girl again, after so long. More RB20's on the road the better. Cheers, Rowdy
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
