Gday All,
I have just turboed my NA RB30, and having retained the 9:1 compression will be running 9psi as an absolute max. Im running the T3 off the VL.
I have an s13 180sx cooler (approx 170x210x50) but apparently its way to small to handle the volume required by a 3.0L. I have been searching around here but all i can find is cheap R33 coolers and threads on ditching them for big FMICs.
What size is an R33 GTS-T cooler? Will it flow well enough for my application? Are there better (not GT-R) stock coolers around that can be had for cheap? Ie $150 or less? Or do I go for a Mk4 Supra cooler which i can get for $150?
Advice please!
Cheers,
Brent
https://www.sau.com.au/forums/topic/39599-intercooler-to-suit-rb30et-low-boost/
2 options i see:
get 2 R33 (or similar) coolers and mount them in parallel if you have room and appropriate piping skills. this will work well me thinks
or buy some sort of intercooler on ebay. you can get some aftermarket items for about 500 on there which will suit your requirements more than one stock r33 cooler.
waz.
or get an intercooler water spray (not very reliable for detonation prevention though)
or try a water injection system
I was going to go for a DIY water spray onto the cooler.. not into the intake, but obviously a spray kit isnt going to compensate for an insufficient cooler.
Brent.
the jza80 TT supra intercooler is not the same size as a GTST cooler.
the CORE ONLY size is 230 wide x 275 high x 130 thick.
then there is the end tanks.
with end tanks it is..
350 wide on top and 290 wide on bottom.
and the inlet and outlet are in the wrong position for mouting in the passenger side.. as they are on the drivers side on the supras...
As you may have guessed, I've travelled this path before..
UNSUCCESSFULLY
I bought mine for $200 and sold it for $200
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
