Gday All,
I have just turboed my NA RB30, and having retained the 9:1 compression will be running 9psi as an absolute max. Im running the T3 off the VL.
I have an s13 180sx cooler (approx 170x210x50) but apparently its way to small to handle the volume required by a 3.0L. I have been searching around here but all i can find is cheap R33 coolers and threads on ditching them for big FMICs.
What size is an R33 GTS-T cooler? Will it flow well enough for my application? Are there better (not GT-R) stock coolers around that can be had for cheap? Ie $150 or less? Or do I go for a Mk4 Supra cooler which i can get for $150?
Advice please!
Cheers,
Brent
https://www.sau.com.au/forums/topic/39599-intercooler-to-suit-rb30et-low-boost/
2 options i see:
get 2 R33 (or similar) coolers and mount them in parallel if you have room and appropriate piping skills. this will work well me thinks
or buy some sort of intercooler on ebay. you can get some aftermarket items for about 500 on there which will suit your requirements more than one stock r33 cooler.
waz.
or get an intercooler water spray (not very reliable for detonation prevention though)
or try a water injection system
I was going to go for a DIY water spray onto the cooler.. not into the intake, but obviously a spray kit isnt going to compensate for an insufficient cooler.
Brent.
the jza80 TT supra intercooler is not the same size as a GTST cooler.
the CORE ONLY size is 230 wide x 275 high x 130 thick.
then there is the end tanks.
with end tanks it is..
350 wide on top and 290 wide on bottom.
and the inlet and outlet are in the wrong position for mouting in the passenger side.. as they are on the drivers side on the supras...
As you may have guessed, I've travelled this path before..
UNSUCCESSFULLY
I bought mine for $200 and sold it for $200
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
