Yeah as above, make sure its on the return line. Shouldnt have any issues with flow really, there shouldnt be much pressure drop through the cooler and the pump should be able to push the oil through a cooler. Remember it does push the oil back uphill when it returns to the reservoir anyway
Random plug is the power steering pressure switch. Basically tells your ECU that the power steering is active and the ECU compensates to keep the revs steady
I don't really see that being a problem (besides maybe the cooler not being in the 'coolest' place), you shouldnt have any issues with feeding oil back. The cooler (once full) is not alot different to it just being a hose. There is probably a slight amount more restriction, but seems weird that you are having issues with this setup
Weird eh? Mine runs exactly the same and it runs perfectly.
I didn't even bleed it, just started the car and turned the wheel back and forth at the same time topping up thr reservoir. Happy days, perhaps see if there's a blockage somewhere.
I've done the same setup on another car years ago, no dramas there too (although was a poster street car that never saw the track).
  • 1 month later...
Matthew, I got quoted around $100 for the single power steering pipe, however I wasn't sure that was the only thing leaking.
I ended getting the entire power steering piping swapped from another R34, cost about $400 with labour.
No more leaks.
  • 10 years later...
10 minutes ago, GTSBoy said:
Ever seen a sock on a PS reservoir in a Jap video and wondered why?
Not until I googled it, now I remember lol. Seems like it's just to clean it up. But it doesn't stop the leak, I have a leak issue though? Thinking whether I need a new bottle, surely not lol.
Fluid gets hot, expands, comes out the cap. The seal might be old, dry and cracked....but realistically, this is something that has been happening since long before the seals should be able to be considered to be old and dry and cracked.
A better PS fluid cooler is a helpful thing. I plumbed the trans cooler from an R34 into mine. Deleted the near useless loop of hardline in front of the radiator that Nissan thought would do the job.
If there's no rubber gasket you need a new cap. There should be a rubber gasket, depending on the car. If you are driving the car hard and the power steering is getting hot it will spit out of the reservoir. I have seen people tap the cap for a hose + overflow catch bottle placed somewhere that it will fit.
There is no seal, that's the thing.
I'm not sure if skyline's have it, I haven't been able to find info on it.
3 minutes ago, GTSBoy said:
Hence why I didn't dwell on the seal aspect of the discussion and talked about why it overflows and what can be done to help.
Ah right, I wasn't going to mess around and install extra crap. Surely it should work right out of the factory lol
Edited by silviaz
What specific car is this? I know for sure my R33 has a rubber sealing gasket on the cap. Not unusual to get a bit of seepage from it either.
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
