Yeah as above, make sure its on the return line. Shouldnt have any issues with flow really, there shouldnt be much pressure drop through the cooler and the pump should be able to push the oil through a cooler. Remember it does push the oil back uphill when it returns to the reservoir anyway
Random plug is the power steering pressure switch. Basically tells your ECU that the power steering is active and the ECU compensates to keep the revs steady
I don't really see that being a problem (besides maybe the cooler not being in the 'coolest' place), you shouldnt have any issues with feeding oil back. The cooler (once full) is not alot different to it just being a hose. There is probably a slight amount more restriction, but seems weird that you are having issues with this setup
Weird eh? Mine runs exactly the same and it runs perfectly.
I didn't even bleed it, just started the car and turned the wheel back and forth at the same time topping up thr reservoir. Happy days, perhaps see if there's a blockage somewhere.
I've done the same setup on another car years ago, no dramas there too (although was a poster street car that never saw the track).
  • 1 month later...
Matthew, I got quoted around $100 for the single power steering pipe, however I wasn't sure that was the only thing leaking.
I ended getting the entire power steering piping swapped from another R34, cost about $400 with labour.
No more leaks.
  • 10 years later...
10 minutes ago, GTSBoy said:
Ever seen a sock on a PS reservoir in a Jap video and wondered why?
Not until I googled it, now I remember lol. Seems like it's just to clean it up. But it doesn't stop the leak, I have a leak issue though? Thinking whether I need a new bottle, surely not lol.
Fluid gets hot, expands, comes out the cap. The seal might be old, dry and cracked....but realistically, this is something that has been happening since long before the seals should be able to be considered to be old and dry and cracked.
A better PS fluid cooler is a helpful thing. I plumbed the trans cooler from an R34 into mine. Deleted the near useless loop of hardline in front of the radiator that Nissan thought would do the job.
If there's no rubber gasket you need a new cap. There should be a rubber gasket, depending on the car. If you are driving the car hard and the power steering is getting hot it will spit out of the reservoir. I have seen people tap the cap for a hose + overflow catch bottle placed somewhere that it will fit.
There is no seal, that's the thing.
I'm not sure if skyline's have it, I haven't been able to find info on it.
3 minutes ago, GTSBoy said:
Hence why I didn't dwell on the seal aspect of the discussion and talked about why it overflows and what can be done to help.
Ah right, I wasn't going to mess around and install extra crap. Surely it should work right out of the factory lol
Edited by silviaz
What specific car is this? I know for sure my R33 has a rubber sealing gasket on the cap. Not unusual to get a bit of seepage from it either.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
