Got a few goodies for sale :thumbsup:
1) Apexi Power FC PRO with Hand Controller for R32 and R33 GTR WILL not Separate
The hand controller is only 2 years old and was brand new in box when I bought it.
Thanks to Paulr33 here is some info on the PFC Pro
What is the "Power FC Pro"
The Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units: 1. Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high-powered cars. The Power FC Pro CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine. 2. 0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
This is definately a FC Pro unit and is in good working condition. It starts up with the Power FC PRo logo and has the ignition cut etc. It has the Launch control. You can set it to your desired revs and when the car is stationary, u can plant the throttle and it stays to your desired revs. IT makes the rally style snap crackle and pop haha and if you are on the track and have a decat it blows nice flames :)
PRICE : $870 ONO
2) Stainless Decat pipe for 32 33 GTST and GTR's plus Stageas
In good working condition no corrosion etc
PRICE : $40 ONO
3) M's Twin GTR Air Pod Filters with adapters for 32 and 33 Std Afm
Good condition, the filters I believe are made by K&N . They have been cleaned and re oiled with the K&N Filter recharger kit
They have no holes and serve their purpose ie air filtration.
The adapters have been repainted black
PRICE: $100 ONO
ITEMS are pickup in Newcastle NSW 1.5 hrs from Sydney or can post at buyers expense :) Can also possibly deliver to Sydney
Nick
Edited by DLOOOK
PRICE : $870 ONO
PRICE : $40 ONO
PRICE: $100 ONO
Nick
PICS now up
Will also post pics of PFC PRO
Have also added the following
-R33 GTR Genuine Carpet Mats Good Condition
$150 ONO
-Genuine "CarBra' for R33 GTST and GTR fits both Series I and Series II
$200 ONO
Hey guys,
-PFC pro now sold
-M's Pods sold pending funds clearing
All other parts still available and negotiable
Also have the following parts
-R33 2dr Stock Catback no rust, good condition (can deliver to Sydney for cost of fuel)
$240
-SAFC I Apexi non digital version has 5 dials for adjustments at different rev ranges
$65
-Compliance Cat good condition. Suits Stagea, Skyline r33 and been told it suits r32 and r34.
$60 good to clear defects Has ID numbers so EPA will heart u !!
N/CE 91006,1109, 91006 212007
-Cusco FRONT Coilovers good condition, no knocks and not too harsh a ride. Similar ride to my Sydneykid Bilsteins
$200
-VSPEC GTR front and rear struts springs good condition no knocks. ~65000km
$200
Cheers Nick
pickup Newcastle or post at buyers expense. As a guide a pair of coilover was about $20 shipped to QLD
Hey mate .
The pic is in the post dated 27/3/12.
Made from Stainless Steel.Will also polish up for you
Features a 7.6CM (3") Inlet and outlet.
<LI>
Features an o2 Sensor hole can be used or left plugged
Bolt on fitment to r32, r33 , stags.
Im in Sydney this weekend for people that might want me to deliver parts..
PODS and DECATS now GOOOOnnnnee.
PS anyone tell me if i can edit the thread title
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
