Having spent the weekend installing my FMIC i finally got all the pipes square and clamped down and i thought. I'll fire her up just to make sure she still woks. But to my dismay. It turned over and almost started but wouldn't fire. Its then I realised id forgotten to disconnect the battery before starting work and i'd shorted the 25A fuse for the radiator fan. Replacing it with the power window one next to it didn't help. Exact same result. Engine turns over wants to start then doesn't.
I then noticed i hadn't connected one of the small vacuum hoses that mounts on to a valve on the inlet pipe, my "kit" didn't have this mounting and when i called the company and asked WTF he said its cool i can just use a t piece from the small hose off the black canister behind the passenger side head light as the is feed into the throttle body its self.
Having done this and not working (same result) i packed it in for the night. then 20 mins ago i got home thought i'd give it another shot and it fired idled for 5 secs then cut out.
Originally i thought it must of been an electrical fault ie blown fuse, but having fired i now think that maybe that vacuum hose (I think it comes from the actuator, small circular brass thing that has a t piece with one feeding to the inlet the other to some other valve mounted on the strut tower) dose HAVE to be plumbed into the intercooler to throttle inlet manifold. Any of you guys got a suggestion??
https://www.sau.com.au/forums/topic/39604-just-wont-fire/
Well its quite strange. I'm not intirely sure. I plumbed the vaccum hose back into the inlet manafold. then went round the car with a test light finding little. then i realised that as i'd blown the fuseable link that the main fuse would be blown so i replaced it with the air con one. But then before planning a trip to Nissan to get ripped off... i replaced the original one it started... so?????????? who knows. but i doubt the problems "fixed".
https://www.sau.com.au/forums/topic/39604-just-wont-fire/#findComment-808175
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
