  • 1 month later...
So I'm waiting at the doctors to get a medical certificate for work and I just think the process is silly. The last thing I wanted to do today is drive around and be in public when I'm sick, ugh.
Pharmacists are permitted to write such a certificate I believe.
I'm a pharmacist > Now I know why I keep up my registration :P
Oh wait, whilst I put on my mask won't you?
*cough
Can I extend on your analogy and place a trampoline behind said beehive?
Mind you, I'm allergic to amoxicillin penicillin and pretty much any other derivative...I'd rather have ill than illin!
So I've now been sick for two weeks. I finished my antibiotics on Monday. I felt fine on Monday after having the previous week off, so I returned to work. I then started feeling unwell again Tuesday evening. I barely made it through work yesterday and I'm off work today. I don't know what's wrong, flu symptoms with a very chesty cough and a mad headache. I'm catching a plane tomorrow so really don't want to be feeling like this :(
Edited by L33SH
Hope it's temporary.
Normally September is past flu season but doctors think there's a repeat set.
I think though that once the westerly winds start up any day now (in Sydney at least) flus will be done and dusted.
What are your current symptoms and are they noticeably different from the first few days of the flu'?
For instance, are you still running a fever, lower respiratory tract infection, is the phlegm productive...?
Current symptoms are continuous runny nose and even when I blow it's still runny, yellowy mucus, throaty cough, but I am coughing less, feeling lethargic and my voice sounds nasaly. People commented at work that I sound sick.
I had all these symptoms during my first few days of the flu, but I also had a sore throat and I lost my voice for a few days. The main symptom I had during the first few days was painful body aches all over. I also had constant hot/cold sweats and shivering, whereas now I just feel a little hot in the face / forehead.
Edited by L33SH
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
