Hello Ladies and Gentlemen,
I've been lurking on this forum for a fair while now, and have owned my skyline since 2005. I thought it was about time I did a bit of a write up of what has happened and what is going to be with my vehicle.
I'm no great scholar when it comes to writing and surely suck at photography, so please forgive me haha.
Okay so I guess I'll start from the beginning;
I fell in love with skylines from a young age, but couldn't afford one for obvious reasons. It wasn't until I was in the 3rd year of my apprenticeship and also had some spare cash laying around did I finally decide to search for my first skyline. I had a friend who had brought his skyline from Autoforce in brisbane, so I gave them a call and sorted out a deal pretty much immediately over the phone. I had just purchased a 1996 series 2 R33 GTST.
The car had a few mods done already to help it along with the sale which included;
- Cat-back stainless exhaust
- Volk wheels
- Tein coilovers (street series)
I decided I would just go ahead and purchase some more parts from autoforce at the time of sale which included the following;
- Monkey front mount Intercooler
- Turbosmart V-Port Type 2 plus Adapter BOV
- Hi-Flow CAT and 3' Dump pipe
- Blitz Spec R Boost controller
- Mongoose 3 point Immoblizar
- Garrett GT35 turbo
- Apexi Power FC ECU
- Splitfire coil set
- Z32 Airflow meter
- DENSO 550cc injectors
- Bosch 040 In-tank fuel pump
- Exedy brass button clutch
- Stainless exhaust manifold
I had the car fitted up with the BOV, frontmount, dump/cat and alarm before leaving the store. Then I pretty much hit the road all the way back to Mount Isa QLD. The long drive home was a good chance to get used to the car and enjoy my new toy.
I had my car for a few months before I took it to the local tuner and got them to install the Blitz boost controller. From what I recall it made 190rwkw ( such a long time ago ). Which kept me entertained on the street for a while before the stock turbo had had enough and decided to exit through the exhaust.
Considering I had most parts stockpiled already I wasn't too concerned, just had to save some money to get it all fitted up. Well time had passed and I was itching to get my car going again, so I dropped t back to the only tuner in town and let them go about their business installing all the gear. A few weeks went past before I got the call to come pick it up, I was pretty damn excited as you could imagine. The tuner gave me about 270rwkw as he didn't want to push it any furthur due to the stock internals.
It kept me happy for another few weeks before the single plate decided to give up the ghost and fail completely. Straight back to the tuner and purchased a Direct racing twin plate. Learnt all about how agressive a clutch can be with that damn thing. But got used to it over time and really enjoyed it in the end.
All was going smoothly for a long time until one night whilst cruising around the cheap manifold decided to crack where the wastegate attached. I pulled it off the road again and stripped it all down. Took the manifold to a local welder to get repaired and add a brace to support the gate. I had it all returned and in my haste to put it all together I made a very major mistake, which would show itself on the first test drive. When it was all together I took it for a lap and being the young and stupid person I was decided to give it a foot full of boost. The gate didn't open and I heard a pop, I pulled the car to the side of the road and it sat there roughly idleing with small puffs of smoke coming from the exhaust.
Once again I pulled the motor down to inspect what I had done wrong and what the damage actually was. In my haste of putting the manifold back together I had switched the wastegate lines around, causing the gate to be held shut. Silly mistake which caused the standard internals to fail.
I couldn't have my car sit off the road for too long as it was my daily. So I decided to go buy another RB25 and put it all back together. I purchased the import motor and within a few weeks had the motor in the car ready to start.
I turned the car over and it wouldn't fire, after checking everything over and over again I performed a compression test. I found compression in nearly every cylinder was low, I couldn't believe I had purchased a dud motor. I pulled the motor down and found broken ringlands on most pistons. I was wild as you could imagine, I just couldn't be bothered with it anymore. I gave up with it and let it sit there for many years.
Now the time has come for me to finish my dream. I have let my car sit there for far too long. Over the past few months I have been purchasing many parts and soon hope to be sending it to Brisbane to get built. So far I have purchased the following;
CP Pistons 0.5mm OS
Spool conrods ( with ARP2000 bolts )
ARP L19 Conrod bolts
Gates Timing belt
ACL main bearings
ACL conrod bearings
ARP Main Bolts
ARP Head Studs
Cometic MLS head gasket
Ross Tuffbond Balancer
Plazmaman Plenum
Plazmaman Throttle body 72MM
Plazmaman Intercooler (680 x 340 x 76mm tube & fin)
Splitfire Coilpacks
ECU - Link G4 Extreme wire in
Innovate MTX-L Wideband O2 sensor & Guage
Tomei IN/EX Cam gears
Tomei Procams 270/10.25mm
Tomei Bronze Valve guides
Supertech double valve springs
Supertech Titanium retainers
Supertech 1MM OS intake valves
Supertech 1MM OS exhaust valves
Supertech Solid cam followers
Supertech valve IN/EX stem seals
Nitto Oil pump
Nissan N1 water pump
Spool imports crank collar
Spool imports mains girdle
Spool imports billet main caps set
Spool imports high volume sump
Spool imports cylinder head drain kit
Bosch 2200cc Injectors
BMI Fuel rail
Bosch 040 Fuel pumps x 2
Walbro intank fuel pump
Aftermarket industries 3L Surge tank
Gator fuel filters
Turbosmart FPR2000
Turbosmart Racegate BOV
Turbosmart 60mm wastegate
Garrett GTX4294R with 1.01 rear housing
6Boost splitpulse manifold ( ceremic coated )
AI Billet Catch can..
Well that's it for the moment. I will update this post as the progress and photos continue. So please stay tuned and thanks for reading. thanks.gif
Cheers,
Gordo.
https://www.sau.com.au/forums/topic/396049-my-r33-gtst-buildup/
Garrett GTX4294R with 1.01 rear housing :blink:
Aye curumba! That's a hot list of goodies, but perhaps a touch overkill on the turbot?
Me thinks the poor little 25 is going to struggle to huff out enough to fill such huge bellows.
Keen to see how it all comes together!
Edited by Cowboy1600
  • 3 weeks later...
Any updates on the build? Lots of money being spent here. All your components for your head (super tech) and so on, very top quality and expensive. Have the same on my rb25. Would like to see how it's come together. Good luck buddy.
the lagg would be ridiculous.
There is people with 26/30's that still complain of the lag.
imagine your 25 trying to spool that up.
Should had gone with a smaller turbo for more response.
But otherwise am interested to see how this comes out like.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
