So hello there! I'm a proud owner of an R32 GTS4 which i picked up last weekend and currently getting things ready for the road.
Can't wait to get into it and take it for a descent spin around Brissy. Got afew things to do first and hopefully by the end of the week i'll have it on the road.
Just got the 32 back from the mechanics. I took possession of my baby on Saturday From John and i"m very pleased with the purchase. Thanks John 2thumbsup.gif . I knew it wasn't gonna be just the boots that need fixing and got my new baby at a good price. Roughly adding it all up, it isn't too bad considering it's a 1989 model and the repairs been done by the previous owner. So it worked out well so far. I hope no more gremlins pop up and set me back further cause i just want to go for a cruise in my new baby. Almost std with coilovers, 18's and boost controller but running std boost. It's even got a std side mount IC and std automatic front lower lip.
Here's a list of what i need done for RWC on my baby. I
* Exhaust front pipe replaced ( has a descent size hole on it)
* Clutch master and Slave cylinder
* Mount the pod filter and get a cover for it
* Steering rack boots and wheel alignment
* LHF Tie rod end and rack end
* LHF Lower control inner ball joint
* Front CV shafts ( still good, might only need boots replaced)
* All 3 wiper blades
* Engine clean up under vehicle
Diognostic Fault eng11( crank angle sensor or circuit ) reseted this morning by Rolscar Mechanical, Darra on Station Rd. He didn't mention the 4wd system but will get that done asap.
ohmy.gif I didn't expect that much stuff to be stuffed but if it needs to, well you then have to. huh.gif It ain't that bad, just starting to go.
Just hope it ain't gonna be over $700 to fix it ( wishfull thinking). Does anyone know how much it'll set me back?
I've got it booked into DRIVELINE SERVICES AUSTRALIA tomorrow and was quoted $300 for all the boots fitted but will ask them to get whatever they can do fom the list above done.
Does anyone have parts that i can buy for the repairs? happy.gif Would really like a front pipe and even the cat too, i suppose i can pull it off my ma61 7mgte but it's custom and i'll have to modify it to fit ( couldn't be stuffed atm, just want to drive it :lol: ). Any tips anyone? smile.gif any help is appreciated with thanks in advance. Cheers
BTW what kinda oil will i need to use for the 4WD reservior in the rear boot? Any oil preferrence?
Edited by howie.v.n75
https://www.sau.com.au/forums/topic/396088-r32-gts4/
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
