Canberra Car Enthusiasts Dyno Day
CC died some time ago and as some of you know it's been reinvented as CCE. As part of that we would like to get some more events happening, the first being a dyno day. I'll be organising this dyno day instead of the usual "Skyline vs Supra" since that didn't really seem to take off last year. Basically, all cars welcome this usually turns out to be a fun day!
Where: ESP in Queanbeyan
Date: Saturday 28th July 2012
Times: 9-5
Cost: $50 per car for 3 runs and dyno print out
Trophies to be awarded for:
Most Powerful AWD
Most Powerful FWD
Most Powerful RWD
I will begin looking for prizes (if you feel your business has something they can contribute such as vouchers please contact me!!) and will announce those as they come on board. Entrants will be given a voting form and can vote for their fave cars to win a prize - will announce categories closer to the day.
I will advertise on some other forums as well, would really like to see a minimum of 20 cars pre paid for this to go ahead. I'll add your name to the list once I confirm your payment. PM for my bank account details, alternatively monies can be paid to either Datamine from CCE (Chris) or myself on a Friday night - tell us of course that you're coming so we know to be there!
Hope to see you all there!!
Entrants:
1. Kat - V8 X5
2. Datamine - Taxi
3. Tyrie - R31 Skyline
4. James - Grumblebee?
5. Nathan - Poopra
6. Drew - A70 Supra
7. Andrew - 300ZX
8. Dan (Potato Sauce) - WRX - Pending payment
9. Ben - Pulsar
10. Matt (Scar) - JZX100 Chaser
11. Michael - RX7
12. Anthony - Mirage
https://www.sau.com.au/forums/topic/396109-cce-dyno-day/
  • Replies 48
Glenn has already told me that if we get over the usual max of 30 cars he's happy to keep running them since it's on a Saturday so you might be in luck there!
I'm also going to try and group cars more appropriately this time to stop the stuffing around and switching on the dyno so all GTRs run in a block where possible.
https://www.sau.com.au/forums/topic/396109-cce-dyno-day/#findComment-6299021
Tell who the usual suspects are?
Ross' car and several of the other Supras aren't on the road and instead of the overall most powerful there's 3 categories. Could be anyone's on the day!
I should also point out thats just trophies. Prizes for the last 2 dyno days I've helped go out to people as voted by all the entrants - everyone has a shot.
https://www.sau.com.au/forums/topic/396109-cce-dyno-day/#findComment-6303318
And a big welcome to Street FX Motorsport Graphics as sponsors! http://streetfx.com.au/store/index.php
They have kindly offered the following:
$100 stickers to first place
$50 stickers to second
$25 to third
(in order of power)
And an additional $25 for one of the categories to be voted on by entrants. There will also be a bunch of stickers to give out on the day.
This is the first of hopefully many, there will be a lot of chances for everyone to win something, not just the most powerful so get on board!! More announcements soon!
https://www.sau.com.au/forums/topic/396109-cce-dyno-day/#findComment-6320151
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
