Tomei Poncams - RB20, RB25, RB26 & SR20
-=Transaction Instructions=-
All transactions are conducted via a portal to our website, usually indicated by the x-click-but22.gif button. Upon clicking this button a new browser window/tab will be opened and the item added to your shopping cart. At this point I would recommend logging (located within "My Account"), this will ensure that the item is added to the permanent cart attached to your account; otherwise it will be lost at the end of the session.
If you haven't already created an account on our website you can do so now by clicking here
Please Note:
  • If you have any troubles you can contact me by either PM or E-mail.
  • The pricing below does not include delivery, unless otherwise stated; this cost will depend on location and is automatically calculated on our website at checkout.
Tomei-Camshaft-Set-Poncam-143036-143005-Nissan-Skyline-R32-GTR-R33-GTR-Stagea-WGNC34-260RS-RB26DETT.jpg
Details: The Tomei Poncam camshafts are designed as a drop in replacement. No dialling in required as the knock-pin has been pre-set so that the cam timing it set for you. No valve spring upgrades are required and is the cheapest and best upgrade for street and track use..
Status: In-Stock on the Gold Coast for immediate pick-up/dispatch.
Price:
*For specifications simply click the corresponding link above. Custom grinds are specially made by Tomei and feature a larger duration than the standard line-up however the same lift.
While stock lasts we are offering a pair of adjustable Tomei cam gears with the purchase of any RB20 or RB26 camshaft set for only $275.00
https://www.sau.com.au/forums/topic/396116-tomei-poncams-rb20-rb25-rb26-sr20/
Regardless of turbocharger, factory or after-market, you can expect to see solid increases in response and mid-to-high range torque. I sadly don't have any before and after dyno charts however results will be highly dependant on supporting mods, boost level, tune... They are definitely a worthy upgrade however remember bigger isn't always better select profiles to suit your application e.g. for an R34 25GT-t with a standard or HKS GT2530/2535 sized turbo I would suggest a set of Type As, a GT3071R/GT3076R, with higher boost levels, Type Bs and larger high-mount setups the custom grind.
