Definitely For Sale
The car is a 1999 - R34 GTR V Spec
Bought it about 24 months ago (give or take) with 48000km on the clock. Thatclock has since been replaced.
As a ball park figure, there would be between70-80,000km on the car all up.
I'm the third owner in Australia, car belongedto another forum member prior to myself.
The car is in great shape save for a fewissues that come with being 12 years old.
stone chips here and there, scratches where you'd expect to find scratches.
There's a small wear mark on the bolster of the drivers side seat and thediffuser lip has seen better days
And a match head sized spot of rust under thebrake light on the boot.
I'm Located near Parramatta
Email: [email protected]
Phone: 0408678265
Well, Ok then.
onto the details.
Engine:
Internals are stock standard with the following bolt ons:
Garrett GT2860R-7 Turbos
Apexi power FC with hand controller
HKS EBC and turbo timer
HKS Adjustable Cams
Split Fire coilpacks
Power enterprise 700cc injectors
Bosch 044 fuel pump
Apexi Pods
HKS hard pipe kit
apexi carbon cold air box
Mines carbon radiator shroud
X force split dumps
Impul Front pipe
Impul blast cat back
Gutted cat.
100mm inter cooler
Air oil Separator
Exedy Clutch
Brakes and Suspension, Tyres and wheels
HSD HR Coil overs - They get shit done
DBA 400 Slotted rotors
Project Mu carbon metal? rear pads
Endless CCA front pads
Standard GTR Wheels
Eagle F1 Symmetricals - 245/40/18 - More tread than you could ever possiblyneed (your results may differ)
In car there is:
Mongoose M80s immobiliser and alarm
320kmh nismo speedo
eclipse head unit with ipod controller (top ofthe range)
Boston acoustic front splits
Boston acoustic rear 3 ways
Clarion 2 channel amp
Alpine 4 channel amp
Pioneer 10 inch sub
Tuned by Croyden Racing developments toproduce 307 AWKW This car has been a pleasure to ownand drive, it's always been well looked after and needs a good home due to a pending move south of the border. Asking $50,000 - My loss, your gain
post-71498-0-75628200-1332856533_thumb.jpg post-71498-0-81492500-1332856546_thumb.jpg post-71498-0-91986500-1332856561_thumb.jpg
post-71498-0-96745700-1332856573_thumb.jpg post-71498-0-43103500-1332856587_thumb.jpg post-71498-0-35034100-1332856598_thumb.jpg
post-71498-0-01615100-1332856608_thumb.jpg post-71498-0-97660800-1332856620_thumb.jpg
https://www.sau.com.au/forums/topic/396156-r34-gtr-v-spec-1999/
Hi,
Please send me VIN number to run through fast.
Do you still have the original cluster?
Also, no 'Ext temp' or 'Int temp' readings on the MFD. Please confirm if this is a vspec GTR.
Thanks.
Still got the original cluster.
The exhaust and intake temp readings on the MFD: When the dumps were changed the exhaust temp sensors went too. After that the next time I activated diagnostic mode to calibrate the throttle reading the computer couldnt find an exhaust sensor so it removed those two 'vspec' options from the MFD.
Can I ask what silver this is? it will be on the build plate listed as a paint code.
There's a few silvers and it's difficult to tell from photos. (athlete silver? sparkling silver? etc..)
Sonic Silver KR4
from memory
Sonic Silver KR4
from memory
looks like it.
same colour as mine, people always comment on how good it looks too :)
very nice car in photos and the one time ive seen it, glws!
  • 1 month later...
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
