Status, which wmi kits were those cars running?
I remember reading in here or elsewhere, that somebody suggested the snow kits aren't as good of quality as an aquamist kit.
If you have worked with both, which kit do you consider to be the better option in terms of quality, performance and engine safety long term?
I think the aquamist is the better kit of the bunch but a little harder to install and setup.
Not saying that there is anything "wrong" with the other kits. I myself am probably gonna go the snow performance kit as I will be installing it myself so it seems a little easier.
Seriously if you are running that much power your gunna need a pretty serious fuel system anyway..
What I am really interested to see now is a E85 fueled car with WMI..
Will it be twice as awesome, or not really..
might give it a crack if no one else does:)
I don't think it works that way ARTZ, my tuner reckons one or the other. The good thing is you can lean out your fuel a bit so it has been known to gain fuel economy as well.
So I'm told, have a read of either mafias or tridents threads on it, I think I remember one of them saying such things
Got a snow s2 if u are looking, am needing to free up some cash atm. Could save you a neat a mount off new.
Just a short drive over to revesby ;)
How much??
Why wouldn't it work, WMI cools your intake charge, e85 cools your exhaust, the colder everything runs the harder you can push it..
Can't hurt to try it, unless somebody can show results that prove otherwise
I'm sure there would be a gain, but it would probably be close to negligible. Would be great for someone to give it a go though!
How much??
bugger.... i bought the dyno files home but i dont have the viewer on this laptop.
Just pulled the soarer with WMI back off the dyno and at 25 psi it made 445rwkw with intake temps averaging 20-24 degrees... it will pull that power run after run after run. It has more in it but we started getting a bit of bleed on the fuel pressure. This car is setup for circuit so it needs to be safe under all conditions so we stopped at 25psi and 445rwkw.
On 98 it would pull one run @ 380rwkw on 20psi but high intake temps held it back from running more boost.. and subsequent pulls would drop power with each pull via the AIT compensation. On 20psi it will pull 390rwkw all day with loads more mid and a near perfect power curve.
Overall timing gain was comparable to e85.
What turbo on that set up?
Did you get that directly from aquamist?
Was from a performance shop with an online store which I found while googling prices. The communication was pretty much non existant and it took close to 4 weeks to arrive.
The failsafe and triggering vavle is what made me choose it over a snow or aem unit. I'm pretty keen to see the results from it
Edited by PSI086
Add a drop of blue food colouring to the 5lt mix and you can call it windex injection. You can actually use some kinds of industrial glass cleaners too, as they contain up to 25% methanol.
Also this is something else that I find interesting...
http://www.hobbyparts.com.au/store/item/nitro004l/fuelnitromethane/
5-10% nitro is considered safe. Higher concentrations can fall out of suspension, but would probably remain in solution better if mixed with methanol first. There is quite a few threads on the waterinjection info forum about this.
http://www.hobbypart...elnitromethane/
Was thinking about this today, if you found a good glass cleaner with some methanol content, you could run the WMI feed directly from the washer bottle correct? (since most skylines have 3+ litre washer bottles) Leaving the only thing visible in the engine bay the injection nozzle and line.....
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
