I have run the snow performance nitro Meth in my system, its basically like a small Nos shot when the system comes on, instant power increase.
mine starts injecting at 8psi and full flow at 25psi, you get the initial surge as it comes on boost and then a second surge shortly after when the wmi/nitro meth kicks in.
I have been running a coolingmist stage 1 kit in my hilux with the controller added in now and wideband aem a/f (3.4l v6 trd supercharger) for ages now. Ive tried running water, water/meth, meth back to back and its all good in a nutshell. Water actually removes more heat than meth but meth gets rid of heat faster. I'm super interested in trying nitro in small quanities but still have a lot to learn about using more and more meth. I have found more and more meth (bigger injector and now trying 80/20 mix) just seems to keep adding in hp. I picked up 30hp just from adding in the original kit with the boost switch only. Its awesome stuff. Methanol is easy for me to come by but for the guys starting out the 50/50 mix is great. My bro bought the basic kit to add onto his car as a safety buffer zone for the track only.
Check out this link for a brief overview of water/meth systems. Its a bit cheesy but its pretty simple and makes perfect sense.
You guys could have used it a few pages back by the looks of it.
Bit of experience with these kits tells me that the coolingmist ones seem to be the best with aquamist a close second (coolingmist has a better controller IMO mapping from not only boost but can use 0-5v from afm if you still have one). Devils own/AEM ok but $$$ not as good as the first two and snow kits are probably better left alone.
^ that video is a nice basic explanation.
Im of a differing opinion about which kit is better though. From what I have read coolingmist kits are a close second to the aquamist kits, but the aquamist seem a little more difficult to set up.
Has anyone run and aquamist or coolingmist kit in a skyline?
I would think a kit that uses boost to trigger injection would be marginally easier to install than one that runs off of IDC or maf voltage.
The more features you get with the WMI kit you buy, will probably make it slightly more hassle to install.
Jet_r31, do you use a coolingmist kit? Are they of reasonable quality in your opinion and have you used/installed any other kits that you can compare them to?
Edited by Mitcho_7
So ive been doing a little research on evolutionM forums and it appears the biggest worry is getting even cylinder distribution so a lot of people run multiple jets to feed each cylinder.
Which brings me to a query, I'm running a plazmaman forward facing plenum and was going to just set up a progressive system with the jet ~8-10 cm from the TB.
Do you think this would cause uneven flow with a ffp? I'm a little concerned that cylinders 1-3 will end up getting all the mist and 4-6 will "starve" if that makes sense.
Idealy I should probably have a jet in each runner but room is pretty tight and IMO its creating more potential for failure points with multiple nozzles and tees for the feed lines etc.
Thoughts?????
Absolutely anything could happen. From what you thought might, to the complete opposite.
If you want the best distribution, move the nozzle further upstream. Even then, you are at the whim of what the water droplets want to do as they go past the (angled, unless at WOT) throttle plate and then through the plenum.
So, correct me if I'm wrong but are you saying move the nozzle further away from teh TB to give the mist a chance to turn to a gas before it enters the plenum?
Mmmmmm, could work. I'm still Seeing cyl 1 getting more of the mix than cyl 6.
I wonder if say 3 nozzles tapped into the side of plenum itself would help with even distribution ?
That's pretty much what I'm saying. A little more time for a larger proportion of the drops to vapourise, a ltitle more time for them to bounce around and come close to occupying the whole cross section of the pipe (You can no doubt imagine that the cone shaped spray from any nozzle is going to push more drops toward the other side of the pipe if there is enough drop velocity, or if there is no enough drop velocity, then drops won't penetrate more than half way across - therefore you need time for the them to tumble around in the turbulence downstream and spread out.)
3 nozzles in the plenum could work really well....or not. Without decent modelling or testing, there's just no way to know where the water is going to go.
Great, looks like I'll have to go and do a fluid dynamics degree just to figure out where to put my WMI jets.....lol
The evo boys love the stuff, especially in the US. Some of thier setups are very complicated with foolproof failsafes, map switching etc etc.
Unfortunately those of us with teh trusty PFC are pretty much limited to a boost cut type failsafe that will switch to running on actuator pressure.
I'll keep researching and see if can work out something skyline specific.
Would be good if u could angle the jet to spray with the flow of air to help vboid what gtsboy was saying.
But Dave i think u are over thinking it. Many people run with a single nozzle system before throttle body without issue's.
Has anyone seen any motor failures due too unever distribution?
Yeah a little right angled jet pointed at the tb would be good, pretty sure it wouldn't effect the air flow in pipes too much.
You could be right though Jez, I may be over thinking it. I suppose if the plazmaman flows ok in it's current state the. It's just going to take any gas from the meth with it and still flows as it should than things should reach number 6 ok.
I suppose that with the stock intake WMI doesn't starve 1 & 6 so probably the same deal???
You'd have to assume that when tuning with uneven distribution, you end up tuning to the cylinder that's getting the least water.
I think this comment makes a lot of sense.
If you listening for knock and you are getting slightly uneven distribution, then the cylinder that isn't getting as much injected into it will ping before the others. As soon as you can hear the engine ping, back the timing off for safety and there shouldn't be any problems.
Having said that, I'm not an expert by any stretch. Most people seem to have no dramas with just one nozzle though... I think like it was mentioned it would be less of a problem with the stock intake on a rb25 compared with a forward facing plenum.
Edited by Mitcho_7
That's what I was thinking Mitcho. On the stock plenum the mist will flow into the middle and "spread" out.
What concerns me with the plazmaman is the most will have to pass over 1,2,3,4,5 to reach number 6.
But as Jez said I think I'm over thinking the whole thing.
Should just connect up the kit and see what happens :)
Has anyone here DIY'd a kit?
Looking at the basic cooling mist stage 1 kit which is just a pump, nozzle, lines and boost switch. Put this together with a "5th injector" style driver running off an injector signal along with a PWM solenoid and presto a fuel proportional WMI kit for under $400 that doesn't use duty cycle to the pump to regulate itself.
Has anyone tried this with success?
Where can you source a solenoid that can be PWM'd and is compatible with water and methanol?
http://www.ebay.com.au/itm/AEM-WATER-METHANOL-INJECTION-KIT-1-GALLON-TANK-30-3000-/360458308794?pt=Motors_Car_Truck_Parts_Accessories&hash=item53ecfd4cba
this looks like a good kit, comes with nice metal fittings/nozzles and afew safety features too
will prob get this in the near future once i finalise my mods and ready for finaly tune.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
