I thought you had plenty of corn juice pumps over there Amon, no ethanol near you?
Im inland a couple of hours from newcastle, and that being the closest place with e85, and my trips being long, and the cost on new ecu + bigger exhaust, injectors, fuel pump, tune etc this is my best and by far cheapest option
i'm no expert,you'll have to look it up, but i think once you mix them together, methanol lasts for a long time
or indefinitly, i thought it has a reaction when mixed with water I know it still f**king hurts in your eyes after 6 months in water..lol
by itself it doesn;t last long.
with a cdi i run water, but with stagea i had water, then 50/50, might go with 50/50 as ignition is
"maybe" not the best(splitfires coils and b@m new volt 18V ignition amplifier), decide when the time comes..
and what it tunes like
i hate mixing though, so might just try water first and if it makes 300rwkw on up to 23psi ish i'll be happy
cheers
darren
Edited by jet_r31
I have a nitro powered hovercraft I made when I was in high school. I bought 10-15% nitro meth for it which lasted up to 6 months no problem. I just squeezed the air out before putting the lid back on.
I'm not planning on ever filling my tank to the top. Just enough for the occasional squirt and half full on track days and keep an eye on it.
I'm getting methanol free now from a mate who races sprintcars :) winning
I think the consensus was it's legal so long as you don't rely on it to pass emissions testing. I'd imagine the WM mix would have to be non flammable if stored in the boot as well.....
Im running a Aquamist HFS6 kit, with direct port injection in each runner of inlet manifold.
well i should not say running but have wired up a HFS6 car is still not on the road/running it is being put together
Keen to hear how it goes
so i need to get a new kit but only want to spend under $500 delivered. I am leaning towards the snow stage 2 kit for $460 delivered, but i am after peoples opinions on what they would get for under $500?
the car is map sensor, running 17psi on stock motor making 290rwkw. Thanks if you guys can help as i am looking at purchasing in the next couple days.
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
