I got the Aem progressive kit which has a fail safe and increases with boost depending how the controller is setup. Also got an inline water filter and was about 330 delivered from summit racing
Edit- looks like prices have gone up a bit :(
Edited by t_revz
A mate rang me up and said he flipped and destroyed his sprintcar so I can have as much methanol as I want.
Maybe this will be enough to motivate me to get my exhaust done (which I now have all the parts for) and get retuned with water/meth :)
Bugger that, run it on straight methanol! :yes:
Seriously considering this as an option, we were looking at an e85 conversion but it was going into the $1000s by the time you uprate injectors, pumps, flex tune etc..
Is there a tuner in sydney with experience in this?
fitted a AEM 40 micron filter to my setup tonight..and shifted it all, its now pre-turbo, so will be interesting to see what it does
efficiency wise.
Doing another with a mate to his 3076 56T .64 ex gate on stocky mani in next week or so aswell, to tap out the turbo to its max, its already on
E85, just want to see how much more flow it can give turbo, we be interesting to see..
cheers
darren
Edited by jet_r31
  • 3 weeks later...
Well, I bought it, but after a rethink the money will lbe better spent on an EBC.
So it's for sale , check the FS section.
  • 2 months later...
just dynoed my car on 98 and then on water/meth injection
600cc CM7 coolingmist jet, added 10 degrees of timing across whole map, same as E85, it would have took more, but that was enough for me
20 degrees on 17psi to 30degrees
cheers
darren
Edited by jet_r31
Got an overlay to show results of before/after? Ignition changes only, or did you adjust fuelling too?
That's a significant amount of increased advance, hopefully should offer the same sort of torque increase offered on E85
What kind of timing do you have after WM install ? I believe im +6 +4, some people tlak about 20.. so maybe I should ask my tuner to play more with timing ?
2) I have a CM7 injector from coolingmist installed in the intake, should I see a gain if I go direct port ?
