Item: Turbo GTX3071r with Anti Surge
Ex Housing : .63 AR 4 Bolt T3 Flanged to suit external gate setup.
Condition: Almost New, only done 500km's (thats five hundred kilometeres)
Price: $1300 Additional Info: See Garrrett website for turbo specs
Item: Turbo GT3076r with Anti Surge
Condition: Excellent, only done 8000km's (thats eight thousand kilometeres)
Price: $1000
Item: Garrett Precision Intercooler Core Only (front mount), supports up to 750HP (31.5" x 10" x 3.5")
Item Condition: Very Good (8,000km)
Price and price conditions: $450
Extra Info: Very good core, minimal pressure loss.
Item: TIAL External Gate
Condition: Excellent, only done 8000km's.
Price: $300
Item: TIAL QR BOV
Price: $250
Item: eBoost Street boost controller
Price: $280
Edited by jobo
https://www.sau.com.au/forums/topic/396188-2-turbos-gtx3071r-and-gt3076r/
Hey, There is a turbo manifold in your pics. What's it off?
  On 29/03/2012 at 10:02 AM, jobo said:
Turbo anyone ?
One is almost new and the other in excellent condition !
They must be sold and need a new home, they are just sitting here in their original garrett box.
Turbo kit for mps gen 2:
turbo gt3076r .63a/r externally gated 4 bolt t3 housing anti surge 4inch inlet
externally gated mani guage sq 10 stainless tubing, that is aprox 1/8 inch wall
t3 flanged downpipe to suit with high flow cat to pass emissions
TIAL external gate recirculated into exhaust stream (not a screamer setup)
CPE catback dual exhaust system with high flow resonator to quieten the system
Turbo inlet pipe
garret core front mount intercooler
Mandrel bended IC pipes
TIAL QR BOV recirculated
eboost street boost controller
Return line oil turboSilicon couplingsT bolt clamps
HKS Air filter mushroom style
Kit fabricated my a mazda racing specialist in puerto rico.
and yes direct bolt on, the only thing you will need is a new oil line to the turbo as its being used in another setup i have, this is not an expensive part.
you also may need some new vac lines depending on how you run the boost controller and BOV.
I had a clutch and lightened flywheel to suit the above setup but it has been sold.
Hey guys gt3076r still for sale, really good condition , not even thrashed, no shaft play, needs a good home.
Can't believe a genuine turbo is taking this long to sell ! If anyone is skeptical please come and inspect the goods and you will see it's in excellent condition and fairly priced !
A new gt3076r is at least 1700 ?
    • Thanks for the info GTSBoy, legend. If there is no downside i'll likely just get the larger bosch units because why not... I remember hearing stories about people washing their bores with fitment of too large injectors way back when, which i guess has made me shy about it now. But happy to know it shouldn't be an issue. Ozdavroz, the little rb20 is a lot of fun- now that i have a little extra funds and time i am very glad to be tampering with the ol girl again, after so long. More RB20's on the road the better. Cheers, Rowdy
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
