Hi,
I feel very stupid as heading states I hooked up fuel lines wrong way round. Just put my rb26 in my car and connected them up not thinking just so fuel didnt drip everywhere and to get them out of the way.
I hooked up wiring and fuel pump and starter, I just wanted to turn it over after rebuild, turned key to accessory and fuel pump started. meanwhile i could hear a strange pressure building noise and quickly switched it off.
very soon after i realised that fuel pressure had built and obviously couldnt get past the fuel reg and fuel passed through the injectors into the cylinders.
Q 1. are my injectors going to be okay after that sort of abuse.?
Q 2. is my fuel reg going to be okay?
Q 3. will this effect run in and the hone job on the bores or the rings themselves? (Fuel was pushed out of cylindars within half an hour.)
Q 4. Will I not know any of the above until I test each thing.
Thanks
Taylor.
Guest
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
