Hey guys,
i have been looking through the threads and theres nothing talking about an r34 gtt lifter being noisy and creating the common ticking noise which mine has.
(lifters in an rb25 went from hydraulic to solid in the NEO when they put some gtr parts in the head for eco and performance benefits)
so was just wondering if someone has had this problem and could give me some tips in fixing it.
the noise is on the intake side of the engine so plan is to pull the rocker off and have a lookey, just wondering what to look for once i get it all apart. will the problem be very obvious orrrr???
i dont want to get all oily and what not and not know what im looking for hah.
also if anyone has done this before is there much chance of fixing this ticking without replacing shims and having to take the cam shaft off and all that?
https://www.sau.com.au/forums/topic/396250-r34-gtt-noise-lifter/
No way to fix without changing the shims and re-doing all the clearences.
worst part of Solid lifters as it is a prick to do in Twincam direct actuation engines
In short, use feeler gauges to find any thing not within spec, remove that shim, measure it calculate how much thicker the new shim needs to be, buy a new shim that thickness and re-install.
Repeat for all 24 valves
Yes it's a real bitch of a job. I haven't done it before but the guy who built my Neo head wouldn't stop going on about how long it took him to get it to the right clearance to suit my cams. Although he may have been just saying that to charge me more labour!
That's so shit zebra haha.
So I have to do all the valves?! O.O how long do you think it'd take two people??
Hmm this is Gunna suck lol. Maybe I'll just make it a week long this and borrow the girls car for the week.
95% sure it's lifters, everyone that's heard it has told me lifters. I think it's lifters. And injectors make there own defined noise.
i was under the impression you can always hear the lifters a bit - one of the first things i noticed when i got my GT-T but everyone who i pointed it out too (and who knew their skylines) told me it was completely normal.
what oil you running?
My R34 always had a reasonably loud ticking noise from the head which wasn't the injectors, never gave me any problems! Maybe you are worrying about nothing and should leave it as is. :thumbsup:
Oil won't have any impact in this application as they are solid lifters.
made a video of it.
yeah i know it wont hurt anything, took it to wakie on saturday and nothing has changed as i was told it wouldnt. just find it annoying, want a nice pur.
between that, the injectors going off there head and the gates timing belt (that you strangly cant hear in the video) its just frustrating haha.
although if i have to change all the shims i think i will just leave it as ive been told its completely fine.
hey I would rather a slight tick and the valve being closed rather then some 1 not knowing how to do it properly and shimming them too much so that they now don't close 100%. Thats just my take on it though. that and unless it sounds like a chaff cutter I wouldn't do mine ever again. just saying
mine used to get a little noisy using nulon oil
changed to gulf western sougi and it was heaps better, now its hard to get sougi so i just use the gw synx-3000 and change it every 5000 kms
try some different oils and see how it goes, the gates belt will be noisy because they use a harder material for the face of the belt and they take a while to bed in
might be worth taking the lids off and check under the rocker covers just in case tho, not overly hard to do and good for peace of mind
Oh that sounds horrible :P worth fixing I think.
Also, you sure the timing belt tension is correct?
made a video of it.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
