Hi everyone, unfortunately I am parting out my r32 gtst after crashing it. The below list are all the bits and pieces I have pulled off thecar. Please buy so I can fund buying a GTR!!
I have the remainder of the wreck at mine but am getting rid of it in about a week. If there is something not there ask, you might be lucky andI might still have it.
All parts are from a 1992 Gunmetal Grey r32 GTST, located in Barden Ridge, Sydney. Generally prices are what I want, but negotiations are always an option
PM or contact me on 0425606137, can post some stuff but ideally local pick is best.
· 3 Inch Bellmouth Front/Dump Pipe With Highflow Cat, stainless steel not some crappy ebay thing– some scrapes on bottom (cost me $1000, used 10000km at the most):$600
· Apexi Power FC for RB20DET: $1000
· RB20DET – with 550cc Tomei injectors (cost me $800), splitfire coils (cost $650), highflowed r33 turbo (a little noisy bearing but runs well) (closer to $1000): $1700.
May seem high but considering the injectors and coils were only installed last September and used for maybe 10000km think it's reasonable. Also has starter motor and I'm pretty sure the AC motor on it.
This combo with a Z32 AFM, power FC, 3 inch turbo back and front mount gave me 210kW
· 260km Nismo Cluster for GTST with LEDs in it:$200
· Wiring Loom from ECU: $150
· Foglights: $60
· GTST Front Seats: $150
Couple of small marks and a small indent (maybe burn) in driver'sseat.
· GTST Rear Seat: $50
$150 for front and rear seats
· Floor Mats – hole where the hook goes into onthe drivers mat and stain on passengers front: $50
· Left and Right Doors – these have everything still on them… trim, mirrors, glass: $150 each
Small marks, and slight scrapes on back of the mirrors but generally really good condition.
· Seat Belts – front and rear incl. middle: $50
· Spare Wheel – bit rusted on the bottom: $20
· Boot Carpet & surround bits and pieces: $60
· Reverse Lights: $50
· Rear Number Plate Lights: $30
· Door Seals: $20
· Door Panels (with skyline written on them): $30
· Rear Bumper – some faded paint but good condition: $100
· Rear Reo Bar: $50
· Front Left and Right Kick Panels (I think that's what they are): $20
· Rear strut bar – not sure of brand: $50
· Boot Lid – A tiny bit rust around one of the holes: $50
· Steering Surrounds Plastic: $20
· Centre Console: $40
· Climate Control: $40
· Climate Control/din/gear stick Surround: $20
· Stock Cluster: $80
· Cluster Surrounding:
· Left and Right Tail Light Globes: $30
· A – Pillars (one clip missing on the back ofone): $30 for the two
· Glovebox and Plastic: $30
· Greddy Turbo Timer: $50
· Dash – Two bubbles which don't look too bad (didn'treally notice them until 6 months of owning): $50
· Interior Carpet – great condition: $75
· Aircon Box: $80
· Heater Box With Heater Core: $80
· Plastic Beneath Windscreen: $10
· 3 Inch Exhaust with Muffler, Fujitsubo brand:$200
· Stock Front, Dump Pipe and Cat: $60 each for front and dump pipe, $20 for cat, all 3 for $110
· R32 GTST Wing - Faint scratch but good condition:$40
· Windscreen Water Bottle: $20
· Coolant Reservoir: $20
· Stock AFM: $20
· Stock ECU: $100
· Boost Tee: $50
· Stock Injectors: $50
· Stock Turbo – no actuator, and suits rebuild, heat shield: $50
· 2 Reservoirs – I think fuel and power steering (see pics): $20 each
Edited by tj88
https://www.sau.com.au/forums/topic/396254-r32-gtst-part-out/
  • Replies 57
Posted Images
Is the bel mouth to suit a stock turbo?
Edit: after reading properly I gues it suits te r33 Tubo, trying to find one to suit a trust td05
Edited by GH05T
Weekend bump here.
No passenger quarter sorry.
The following are sold pending payment:
Center console, boot carpets, cluster surround, steering column plastics, a pillars,
Make an offer on stuff people, the worst i can say is no
I have the demister vents, but would prefer to keep it with the dash. That said if the dash doesnt sell in a while ill probably pull out the vents and let you know.
Sorry no suspension arms.
Sold Parts:
Stock Turbo, Steering column plastics, boot carpet, a pillars, gearbox, center console
Cluster surround on hold for now.
Trying to locate the parcel shelf brake light - will let you know if I track it down
More sold bits and pieces:
3inch cat back exhaust, wiring loom, spare wheel, indicator stalk, accelerator cable.
Ill be getting rid of the wreck probably this weekend so if there is some little bits and pieces you want let me know, maybe I can help.
Any interest in the engine? Just to point out it still has the exedy heavy duty clutch and starter motor on it as well.
I will be looking at pulling the injectors, coil pack (both already have interest), turbo and bits off within a week
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
