Hey fellow Stagea owners,
For some time now I have noticed my hicas light illuminated on my dash cluster, It's starting to frustrate me a bit whilst cornering fairly hard with a bit of spirited drive i notice the back end seems to skip/jump over the road. Is anyone else familiar with this issue, The back end seems to sway from side to side when going over certain bumps over the road at higher speeds from time to time also.
I believe there is a diagnostic mode for the hicas, recently have also had a wheel alignment and 4 new tyres put onto the car but the light was previously illuminated even before the new tyres and alignment.
Looking forward to your responses, Best regards Chris.
https://www.sau.com.au/forums/topic/396271-rs-four-s/
jack your car up and check under your rear diff, there is a metal case there, undo the 2 or 3 bolts, then you will see your hicas setup under there.
check if your plug is connected.
i bottomed out my ass on my stag and i broke the plug. never noticed that the metal cover had a ding in it, but i broke the plug off.
then the hicas light came on and my ass was all over the road.
so check the plug first
https://www.sau.com.au/forums/topic/396271-rs-four-s/#findComment-6295346
From time to time is decides to work for a bit but as soon as i start driving it spirited the light illuminates and as you said the ass end is all over the place, Not a safe feeling...
Will check tomorrow about the plug could be a loose connection or something
https://www.sau.com.au/forums/topic/396271-rs-four-s/#findComment-6295930
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
