There are only a few days to go until this year’s Sydney Jamboree!
Staged over an epic day & night at Sydney Dragway it’s on this Saturday March 31. It is not just a drag racing event, it's one of Australia's Largest Hi-Tech Automotive Lifestyle event.
Alongside 11 Sport Compact & Sports Bike categories of racing scheduled for the day/night, there will be a huge Show-N-Shine presented by Juice Polishes as well as a Motorcycle Stunt Show.
Add to that the essential, Car Audio Sound Off Comp, Club & Trader displays, as well as Dance Shows and the Sydney Jamboree trademark Babe ‘n’ Bikini Comps.
Online pre-entries have now closed but you can still enter the Show-N-Shine & Sound Off Comps on the day. Just in the Show-N- Shine, there are over 30 trophy categories and lots of prize packs up for grabs!
On the day registration for the Show-N-Shine and sound off is between 6:30-9:30am. Entry fees are as follows
Show-N-Shine - $60
Sound Off - $60
Entry includes both car and driver entry.
Ticket Prices
Adult General Admission - $25
12 - 16 years - $20
Children Under 12 free
For trophy categories checkout http://www.jamboree.com.au/sydjam/show/
For all the details checkout http://www.jamboree.com.au/
https://www.sau.com.au/forums/topic/396277-sydney-jamboree-31st-march-2012/
that JEM r32 gtr was abit of a disappointment, shit launch on his first pass, still managed a 10.6,then second pass made it half way then blew a heap of white smoke, definetly had the potential for some realy quick times !
The black JEM R32 GTR (that made 830rwkw) ran a 10.6@152MPH with a poor/soft launch on it's first pass. Then attempted to step it up on the next pass and proceeded to smash the engine to smithereens from the start line to the 1000ft mark.
The silver R33 from Birrong Automotive ran a PB 7.7@182MPH.
Also, Maatouks SOHC RB30 [GH 0747] ran a PB 7.83@172MPH
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
