Hi all,
I'm wondering if anyone knows the standard size for a R33 (1996) GTS-4 4-stud rear brake rotor/disc. I've looked around online (car is in the shop at the moment) and can only seem to be able to find front sizes or general R33 model size.
Is it a 297mm radius? that's the only number I've come across...
Also, anyone know where I can go about getting rear discs in the Melbourne area? I've been quoted $180 each and wanna see if I can find them anywhere for cheaper.
Thanks in advance for your help!
Edited by d4l337
https://www.sau.com.au/forums/topic/396304-rotordisc-size/
About rears - that's not as easy a question as it might look, there are two different p/n's for 4wd R33 rear rotors and it has something to do with production date - what is yours? Diameter and thickness may be different.
If you have pre-01.96 model, then they are same as S13, 266x9mm, and should be fairly easy to find.
If yours is post-01.96, then things get slightly more complicated, e.g. I couldn't find one for a sensible price, and diameter is also unclear, but they are cross-referenced as a replacement for A31 cefiro and C33 laurel rotors.
Are your rear rotors vented or solid?
Edited by Legionnaire
https://www.sau.com.au/forums/topic/396304-rotordisc-size/#findComment-6297649
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
