Hey guys and girls....
Have been tossing up for awhile weather to get a r32 GTR or 34 GTR....
I like white in both cars and ive seen some hot white 34s going around but not many 32s?
Can someone post some pics of HOT white R32GTRs
Also in the 32s what little add on body wise is there without going stupid like bolt on flares etc? Just things to set it apart from others?
Any help would be great
https://www.sau.com.au/forums/topic/396321-r32-gtr/
Cheers guys!
Im still unsure.
I just dont think the 32 GTR looks different enough from the GTST without changing kits etc :/
Those canards on the 32s, where do you get them from?
I'd just go a Nismo body kit:
Front intercooler vents on front bar
Bonnet Lip Spoiler
Boot Lip Spoiler
Side skirts with rear quarter panel spats
Trust Rear Pods (In picture)
Personally I don't like the Bonnet Lip Spoiler.
R32 GTR's have streamline looks, so they look better with a nice subtle kit
https://www.sau.com.au/forums/topic/396321-r32-gtr/#findComment-6296299
Google images broken on your computer?
maybe look in the yellow pages for pc repairs in your area? the quicker you get it fixed, the quicker you can google search for pics, and stop getting everyone else to do it for you...
https://www.sau.com.au/forums/topic/396321-r32-gtr/#findComment-6299355
Thanks guys! cheers for the build thread!!!!
Argh still cant decide 32 or 34..... seems like if i get a 32 everytime i see a 34 go past ill be like s**t should have got one of them... BUT if i get the 32 i can chuck a bit of cash on mods to it... where as i cant for the 34 :/!!!!
https://www.sau.com.au/forums/topic/396321-r32-gtr/#findComment-6300152
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
