Well the NVidia GTX680 has been released in answer to the AMD HD7970
I really enjoy the Anandtech reviews so further info here if you weren't aware:
http://www.anandtech.com/show/5699/nvidia-geforce-gtx-680-review/
Seems NVidia have indeed pulled a nice punch with the GTX680. I've been waiting to buy a new GPU since the end of last year as BF3 & Skyrim are struggling on MAX with my slightly older card these days.
I'm not set on buying a GTX680 just yet, but given they are priced the same (or near enough) as a HD7970 this might promt AMD to review their pricing structure given the NVidia card really gives them a good beating.
See what happens with pricing over the next 3-4 weeks i guess!
https://www.sau.com.au/forums/topic/396335-current-gen-gpu/
GTX680 - $700
HD7970 - $600
Hence I would envisage a price shift of large proportions given the NVidia cards really are much faster.
Problem is they are almost priced identically in the USA ($500)... But somehow the NVidia card has incurred a 40% price hike for "no apparent" reason with our dollar at parity.
I mean the reason is simply suppliers are gouging as always, of course they all deny that and cry poor
$500 I can justify as i usually spend around $400. $700 however I cannot.
I'll also look following to see if i can get a the lower model card and flash the BIOS or similar. I think a good spend on a GPU at the moment will hold off most games for the next 2 years, rather than having me update every 18months like I have been lately.
https://www.sau.com.au/forums/topic/396335-current-gen-gpu/#findComment-6295525
Overseas Group buy anyone??
Give us in the loop Ash as to what you decide regarding flashing etc and value for money.
I am stuck somewhat as my centurion case holds my 5870 ok and could hold a 6950 but nothing bigger, it appears that the new 7980 cards are quite large so i would have no luckj fitting it in. I cannot see though the size of the 680 if it is smaller i may have no other choice than to go back to nvidia.
Mind you my 5870 is still packing a good punch, but just like Clarkson i want more POWA!!
https://www.sau.com.au/forums/topic/396335-current-gen-gpu/#findComment-6297910
$700 video cards... reminds me of the time I spent that around that much to buy my Radeon 9700pro which at the time was the fastest GPU in the world (beating the Nvidia Ti 4600).
Now I can't even give it out for free...
https://www.sau.com.au/forums/topic/396335-current-gen-gpu/#findComment-6302536
  • 1 month later...
Yup i am thinking the same thing.
Will buy just before the end of financial year then claim tax back. As mentioned before i am limited to a card in my case 11 inches or less. so the 670 looks the goods as a nice jump from my old trusty 5870.
give it a month and hopefully the novelty has worn off and prices come down a bit. I am also waiting for the aftermarket reference cards like the MSI lightning editions.
https://www.sau.com.au/forums/topic/396335-current-gen-gpu/#findComment-6356149
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
