well i'm not a mechanic, nor have i pulled down a RB before, but i have taken off the cover for the timing belt, and they almost look like the locators for the backing plate behind the timing belt to attach to the block, but like i said, i wouldn't know for sure
The head is sitting square and in the right position I removed a couple of head studs to check, but I won't take the risk of it shifting under heavy load its been 4 years since i drove my gtr and god i miss it, ive just been down to gm Motorsport in melton and bought my self a 1.69oz tube of arp assembly lube enough to build the motor 20 times! So off to the workshop for another tear down
Cheers cam
They are definately the head to block dowels, I installed mine just the other day and they were the same (with the split). I also used ARP studs with them. I would definately take the head back off and install them.
The motor is still on the engine stand, I prob used the stud kit as alignment and not thought twice, the r33 engine manual has no mention of there being locating dowels which is why I may have over looked it, guess what I'm doing this weekend then god damn it!!, unless you guys think the arp stud kit would line the head up enough?or best not to risk it?
  • 2 months later...
After 4 years of slowly gathering parts for my rb26 im finally putting her back together(spun bearings) 4 years is a long time and cannot remember for the life of me where the hell these go!!they where in the same zip lock bag the 3 bolts for the lower front cover was in but cant see them being used for the front cover, hope some one can reconize these 2 sleeves i guess you would call them? and save me having to pull the motor apart again!
Did you work out where they go?
I had lower front cover off... also the entire intake side and water pump. Have ti all back together and have these two suckers left over! Would rather not have to do it again.....
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
