Righto so i just got my R32 GTR back from the tuner
The car made 375rwkw at 18psi on pump fuel before the Fuel pump decided it couldnt flow anymore, that and the injectors are at 75% duty so they'll be swapped out as well..
and before everyone jumps in and tells me the nismo should flow more, i dont need to hear it. Yavuz tunes a certain way and its been working pretty well so far
Current set up is:
Borg warner 83/75 on a twin scroll manifold
Brand new Nismo intank pump that been wired to recieved the correct voltage, (so i know its pumping as much as it can)
Standard fuel rail and reg
Sard 800cc injectors
standard fuel lines
Now what i want to do is run the turbo at 25psi which will/should make in excess of 430rwkw on pump, BUT i will also be running an EFLEX tune with ethonol...
ive already got the ID 2000cc injectors on the way, and ive decided to get a twin entry fuel rail with an aftermaket reg, fuel lines will also be upgraded.
The decision that has to be made is what fuel pump set up to run, keeping in mind i will only be using the car for street duties mainly and light track days...do i:
1. Run a surge tank and have the nismo feeding two bosch 040's,
2. Sell the nismo and run twin intank 040's, or
3. Buy one of these big suckers and run a "Y" pipe so both sides for the rail can be fed
http://aeromotiveinc.com/products-page/fuel-pumps/11104-eliminator-fuel-pump/
problem with number 3 is that ive heard it doesnt flow as much as it claims
what do u guys reckon? if ive missed anything let me know
cheers
https://www.sau.com.au/forums/topic/396360-need-more-fuel/
What ever you decide, don't buy an aeomotive pump...
My personal preffrence is a large single pump... whack a surge tank in if you'r looking at alot of track work- or not if you dont.
Keep it as simple as you can.
Cheers
Justin
https://www.sau.com.au/forums/topic/396360-need-more-fuel/#findComment-6295785
Has anyone run a twin nismo intank setup before? I've heard of twin 044's so I imagine it's much the same yea?
I want to try and avoid the surge tank and obvioslusly I can get two Bosch pumps for the price of 1 nismo, I dont mind the noise of the 044's but obviously nismo is the preferred :thumbsup:
https://www.sau.com.au/forums/topic/396360-need-more-fuel/#findComment-6296019
Cheers
Justin
Simple is good, though I'm not really sure what else is out there in terms of big single intank pumps... Anyideas?
It'll need to flow well and truly more then a nismo
https://www.sau.com.au/forums/topic/396360-need-more-fuel/#findComment-6296034
Deatschwerks DW300? Solved my fueling problems and is as quiet as a mouse :ph34r:
http://www.deatschwerks.com/products/fuel-pumps/dw300-in-tank-fuel-pump
http://forums.evolutionm.net/automotosports-illinois/566110-bosch-044-aeromotive-stealth-340-deatschwerks-dw300-walbro-255lph-fuel-pump-test.html
I'm not sure if it will flow enough for 430rwkw though especially on ethanol... that is some serious mumbo!
https://www.sau.com.au/forums/topic/396360-need-more-fuel/#findComment-6296188
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
