HI,
Im not sure if this is where i ask for help, opinoins and questions but here we go.
I have R32 GTR and would like to upgrade my brakes. A mate of mine has a set of 2010 Ford FPV Brembo calipers that hes thinking of selling and i know ill need to make a braket to make the bolt up but will the work?
Any help would be appriciated
https://www.sau.com.au/forums/topic/396361-2010-ford-fpv-brembo-brakes/
any place that does brake stuff should be able to answer that for you and tell you the pros and cons for doing so. prob will fit, but your talking about the 6 piston 1's right? so you'll need atleast 18's, prob even 19's to fit those brakes under your wheels, if i were you i'd check clearance first. keep that in mind
The ford brembo calipers will require a 1inch master cylinder and some drastic changes to proportioning if your retaining the original rear calipers.
A cheap option they may apear to be but once you factor in the $6-800 for adaptors, $2-300 for a master cylinder,$1-200 for new front lines, $8-1000 for apropriate rotors (factory ford rotors won't work due to the ofset) $2-300 to correct the bias issue.
It actually works out more economical to buy a kit designed for the nissan
First of all - do you know piston sizes of the calipers? They may be useless for you.
Second - you can always buy them and let them lie on a shelf while you're getting yourself all necessary components, including rear upgrade, a bargain is still a bargain. Not an option if you want a quick solution though.
As per the others. I am guessing about the size of the 6pots, but having measured up the 4 pots their pistons are waaaay bigger then F50s which are borderline too big themselves. So F50s are 44mm and 40mm pistons, and from memory the Fords were 48mm and 44mm. So you would assume that the 6 pots offer the same piston area as Ford woudl not have re-engineered the master cylinders, pedal ratio etc for the same model car but with an updated 6 pot Brembo vs 4 pot Brembo (that is an assumption, but I dont think its too long a bow to draw)
So it makes no sense to use Ford calipers on a Nissan. Nissans have all the brake balance and force you will ever need just with a pad upgrade. What you are trying to do is get more consistancy out of the brakes and larger pistons dont do anything for you in this regard, you need more rotor and cooling, in turn this often means you need similar or smaller pistons depending on what you are doing on your rears.
To give you an idea just how fussy the balance can be when you sway too far from the more proven kits....have a look at this vid below. I had just removed my Brembo F40s and was half way through engineering up my custom 343mm Stoptech 4 pot kit when a skidpan day came up. Not wanting to miss out I threw my std R32 GTR calipers and rotors back on the front.
So this means the fronts were 296mm rotors with Sumitomo calipers which have 40.4mm pistons. The rears were Brembos with 300mm rotors and 40mm pistons. Now these rear brakes normally run with front calipers that have the bigger pistoned calipers up front in 44mm and 38mm pistons. So what I was running with was calipers 3%smaller then usual at the front...the result
Now what you would be doing running the Ford calipers is running about 25% more than usual caliper area. So you can see problems on the horizon >_<
And an old favourite post of mine from something like 2002. If you are thinking about an upgrade its important to understand the following just so you dont have unrealistic expectations of what a brake upgrade is going to achieve other then cost you thousands :thumbsup:
Car & Driver did a test on brake upgrades. Test Car was a WRX (US Spec which only uses two piston sliding caliper, not as good as Nissan 4 spot or later Model WRX 4 pots)
So tested kits were, std car, std car with upgraded pads and fluid, Brembo F50 Kit, Brembo Lotus Kit (Similar to as fitted to GTRs, 44/38mm pistons), Stoptech kit and Prodrive Kit (Alcon)
Stopping Distances 70mph - 0 , 3 Stop
Brembo F50;________________ 185 / 183 (Average / Best)
Brembo Lotus; ______________ 200 / 196
Prodrive; __________________ 198 / 194
StopTech;__________________ 187 / 186
Stock; ____________________ 205 / 196
Stck with pads and fluid; ______187 / 184
The above figures are all in feet, one stop difference between pad and fluid upgrade and crappy std sliding caliper brake setup and massive Brembos is 1 ft...lol 30cms. And over 3 stops the average is 2 ft...lol 60cms
So you can see the one stop max of the upgraded pads and fluid is damn good when you consider the $$$ to % difference.
Stopping Distances 100mph - 0 , 25 Stop
Brembo F50; ______________ 299 / 288 (Average / Best)
Brembo Lotus; ______________305 / 294
Prodrive; __________________ 308 / 295
StopTech;__________________ 297 / 290
Stock;_____________________ 340/317
Stck with pads and fluid;______316/299
Not the world of difference you would be led to believe from the "i sailed up the inside under brakes because my massive brakes allow me to brake so much later"
Specs of the kits:
Rotor Weight (pounds) Size in inches (diam / thk)
Brembo F50;.................15.8......................... .13.1 / 1.3
Brembo Lotus;..............12.9.......................... 12.9 / 1.1
Prodrive;......................16.5............... ............13.0 / 1.1
StopTech;...................13.9.................. ........12.9 / 1.1
Stock;.................. ......14.2..........................11.6 / 0.9
Caliper Weight , Piston Size, (mm)
Brembo F50;..........8.6 pounds...........40 / 44, Leading / Trailing
Brembo Lotus;.......6.8.......................36 / 40
Prodrive;...............9.1..................... 34.9 / 41.3
StopTech;.............9.3.....................36 / 40
Stock;.................10.8.................. .43 / 43
...and COST!!!
Brembo F50;.......................US$2,995
Brembo Lotus;.....................US$2,595
Prodrive;.............................US$1,999
StopTech;...........................US$1,695
Stock with pads & fluid;....... US$130
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
