Did manage to granny it there with the injectors, ran rich as and was fouled to shit by the time I arrived, old spark plugs were stuffed anyway.
Just a warning on the ceffy computers, the tuner actually had to get the developer of the Nistune in to try and sort it out, apparently the ceffy/laurel computer has a slower processor than the 32 and also for some reason will not hold AFRs as consistently, I traded mine in for a manual 32 gtst computer.
Also if anyone has a 32 computer with a black (instead of blue) sticker these have a faster processor again (usually only found in the 1993s).
Currently making 197 rwkw @ ~17 psi but injectors are playing up a bit.
Is there anything wrong with running a Laurel computer?
yes the are crap, we wont nistune the A31 and C33 ecu's... we replace them with r32 ecus (plug str8 in)
All the c33 and a31 ecu require a type 1 board not the type 2 nistune board that the r32 ecus take. The r32 ecu are farmore modern and take to tuning fa better.
i have a C33 myself.
Actually these computers are virtually identical to the HCR32 ECU. Problem is that the A31/C33 ECUs dont have consult capabilitiy which was the main difference (so the normal lines for consult RX/TX/CLK dont exist on these)
Type 1 board 'USB consult' was adapted these ECUs but tuners reported AFR inconsistencies with A31s so we have dropped using the board with those ECUs in the meantime until I investigate further. I suspect some of the extra code added is clobbering the ECUs internal variables so I need to go through that ECU patch firmware again and try and workout whats going on. Would be good to get those going since I have a stack of A31 ecus here and they potentially could support RB25
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
