I'm probably going to be looking into bags for my sedan around next year as its impractical to have a car lowered at all where I live and I plan on keeping her for a long time and putting a bit of work into hense the decision
im factory ride height with after market 18x8f and 18x9r with 235/40 R18s all round (bit of stretch on the rear and none on the front)
i scrape front if i take it nose on, if i angle i dont.
with a full car load i scrape aswell, but most times im good.
Because???
Many people have done this and recommend it.. lowers by about 25mm without sacrificing too much ride quality.
I can't imagine lower mine any further. Don't know what ride height i'm on but it's stock and i'm scraping everyday i drive.
technically you are not factory ride height anymore because you are running 40 profile instead of 45. You are approx 20-30mm lower than factory with those tire profiles.
mine has always scraped.
back when i had standard shocks and springs with 18x8 +35 factory premium alloys and 235-40-18 tyres.... the standard springs had so much travel that the under engine plastic panel would drag along the ground AFTER bumps in the road... the worst suspension ive ever driven on.
now with 2003 model 350z shocks and springs with 20x8.5 +35 235-35-20 up front and 20x10 +42 265-30-20 stretched in the back..... i rarely scrape under the car, but always drag the custom front lip (its lower than parking bay concrete blocks.... an upright iphone barely fits ) and the rear muffler drags occasionally when reversing over driverway gutters.
have only slammed the chassis rails once.
and even with 250kg of fat people in the back seat, the rear only dropped an inch
fyi: the 350z shocks and springs originally felt way too stiff for my liking... but ive grown used to them and am quite happy with the ride. And theyre not stupid low either. Nightcrawlers is definitely lower than a slugs scrotum.
Edited by Deep Dish V35
Tyre sidewall height of a 235/45 is 105.75mm. The sidewall height of a 235/40 is 94mm. Overall tyre diameter changes by 23.5mm but radius only differs by 11.75mm (axel to tyre edge) which is the amount the axel will be closer to the road.
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
